Results 1 to 3 of 3
    Jun 2013
    From 2x10 (Sram) to 3x10 (Shimano)
    Pls Help!
    Currently running on Sram 2x10.
    1) Can I change to Shimano FD (either SLX or XT) 3x10 with chainring 42/32/24T?
    2) by using DMD adapter, can solve this problem?
    *Model: Stumpjumper 2010 (photo attached)Name:  2010stumpjumper26.png
    Given that my wife's 2010 stumpjumper came set up with a 3x9 slx derailleur, absolutely. Just make sure you use the correct mount. You need to match you front derailleur to the shifter so you will also need a 3x10 shifter. My question is why are you going from 2x10 to 3x10? If it is a gearing issue, it most likely can be solved by a chainring swap which will be less expensive and maintain the better shifting that a double front provides.
    Riding slowly since 1977.
    Jun 2013
    Thanks for your reply!
    I just couldn't let others leaving me behind.
    In our place we normally facing about 30% on road before start an off road. Most of my friends running 3x9 & 3x10 hard tail, it's an advantage for them on flat road.
    However, problem solved now by adding DMD adapter and minor modification.
  1. Converting SRAM 3X10 to 2X10
    By Merost in forum SRAM
    Last Post: 09-18-2012, 11:19 AM
  2. 3x10 to 2x10? Shimano and SRAM??
    By zixxerian in forum General Discussion
    Last Post: 03-09-2012, 11:42 PM
  3. Shimano 3x10 to 2x10
    By oshaden in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2012, 01:33 PM
  4. SRAM X9? 2x10 or 3x10?
    By Triaxtremec in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2011, 11:13 PM
  5. SRAM X9 3x10 vs Shimano XT 3x10 DynaSys Drivetrains
    By CasinoKiD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 09:43 PM
