Results 1 to 5 of 5
    k_z
    k_z is offline
    2x10 specific FD
    Just changed my drivetrain to 2x10 XT setup. Only thing left is SLX fd-M660 front derailleur, direct mount (bike is SC Blur LTc) and I am having two problems with it.
    It sits way too high above large ring and cant get it any lower and cant make it not rub... would buying fd-m 786 for example help with it?
    Sent from my Kindle Fire using Tapatalk 2
    meow meow
    Reputation: b-kul's Avatar
    you have tried to mess with the limiter screws?
    k_z
    k_z is offline
    Re: 2x10 specific FD
    Definitely. First thing i tried....
    I went 2x by removing my large ring and setting the limit screw to lock out the big position. I tried all sorts of things to make the 3x FD work.
    First I moved the FD as low as possible. It didn't shift well, because I couldn't get it low enough for the small and medium-position ramps inside the cage to align. So I put it back to stock height and of course it shifted OK, but if I were in the small cogs in the back and shifted from inner to outer in the front, the chain would walk off the outside of the ring when shifting up.
    So I finally said screw it and got a 2-speed FD. Get yourself a 2-speed SLX. They aren't expensive.
    BTW, here's a tip for adjusting the FD limit screws. The high limit screw doesn't adjust anything -- it just keeps you from shifting off the outside of the big ring. The two adjustments are the L limit screw and cable tension (barrel adjuster).
    So turn the H screw CCW to get it out of the way, adjust the L screw and barrel adjuster. Shift into the big ring, and set the H screw so it just barely touches the cam or even has a little gap.
    k_z
    k_z is offline
    So at the end I purchades 2x10 specific front derailleur (FD-M786 D) and it actually does make a lot of difference vs. 3x9 SLX one. In has narrower cage and mounting slot allows to position it where it should be vs. large ring.
  1. 2x10 FD-m785 work on 3x10 FC-m660 converted to 2x10?
    By govertime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-03-2012, 07:17 AM
  2. XT 2x10 Crankset Compatible with SRAM 2x10 Drive Terrain??
    By sbchisholm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 07:30 PM
  3. xx vs xtr 2x10 - specific question though
    By wyolink in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-19-2011, 04:05 PM
  4. Replies: 10
    Last Post: 03-08-2011, 04:06 AM
  5. 2X10 Specific Question
    By cornfish in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-22-2011, 11:54 PM
