Results 1 to 5 of 5
    Reputation: BaeckerX1's Avatar
    Oct 2007
    2x10 to 3x10 Questions
    I just purchased a new Pivot Mach 5.7 that I got a great deal on. It came with a 2x10 X9 drivetrain with a 26/39 X9 crankset. The 2x10 is great, but I've found with my knee problems I really miss my granny gear and just can't push the harder gear up some of these super steep climbs in Colorado. So I'm going to throw a 3x10 crank on and replace the outer with a bash, then sell my 2x10 crankset. The Pivot uses an E-Type or S3 direct mount front derailleur so I did purchase a new X9 S3 top pull to use because the current one won't work. You can't really change the derailleur height on Pivot's setup.
    My plan is to use the existing 2x10 shifter on the 3x10 crank since I'll be using a bash and won't use the big ring. Problem is I keep hearing that I'll need a new shifter too because the cable pull is different. I'm not seeing why. The throw is only 13 teeth on a 2x10. The difference is 11 teeth between small and middle on a 3x10. With careful aligning of the limit screws on the front derailleur and proper setup, I don't get why it won't work. That's what everyone keeps telling me though. Is the 10 speed stuff really that picky or is this just to try and get me to spend more money? I'm already buying a new front derailleur and crank. I just don't get why I need a new shifter too. I'm OK is shifting up front isn't completely smooth and flawless, as long as it works well. Thanks!
    Gotta get up to get down.
    LMB
    Former Bike Wrench
    I'm running a 22/33/bash 2 x 10 with the 2 speed front shifter, the front derailleur is a S3 X-7 but I can't remember if it is a 2 x 10 or 3 x 10...I will look tonight.
    Oct 2007
    Quote Originally Posted by mtnbiker72 View Post
    Thanks. That will help. How is the performance?
    LMB
    Former Bike Wrench
    Quote Originally Posted by BaeckerX1 View Post
    The best front shifting I have ever had, even bad timed shifts to the granny seem to work.
    Former Bike Wrench
    It is a 2 x 10 front derailleur as well, judging by the space above the chainring it is probably the 39/26 version.
  1. Why? 3X10 vs. 2x10
    By jollybeggar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-01-2012, 07:12 PM
  2. Q Factor XTR 2x10, 3x10 and XT 3x10
    By fishy in forum Shimano
    Last Post: 04-19-2012, 11:44 PM
  3. XTR Trail or X.0. (3x10 vs. 2x10)
    By blaadd in forum 29er Bikes
    Last Post: 01-19-2011, 12:32 PM
  4. From 3x10 to 2x10..help
    By Mozzer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2010, 01:14 PM
  5. 2x10 to 3x9 or 3x10
    By dlorga in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2010, 02:05 PM
