Results 1 to 10 of 10
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    22-42 cranksets?
    22-32-42 is a common size for mountain cranksets. Is there a way to go 2xN by just dropping the 32-tooth ring? You'd keep both the low 22-32+ granny and the fast 42-11 gears that way. Maybe I missed something, but why isn't there a 22-42 crankset around?
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by Mtn-Rider View Post
    Hard to shift to the bigger ring ?
    No sweet spots ?
    Next trend ?
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Former Bike Wrench
    Front derailleurs are not designed to handle that much of a drop between chainrings, most doubles are 14t max (ie 22/36 or 28/42)
    most of us with that initial triple-ring setup have gone to 11-36, as it is the best compromise- good shifting and good enough range of gears. I tried moving my 42t gear to the middle position- you have to be very deliberate with your upshifts- it is no where near as smooth as 22 to 36. Also, you may have frame issues with that large of a chainring in the middle position. 36t ring has worked fine enough for me for at least the last 10 years- not worth using a 42t to me...
    Reputation: hootsmon's Avatar
    Quote Originally Posted by mtnbiker72 View Post
    mtnbiker72 hits the nail right on the head!
    For example, my present 2x9 setup has 22/36 chainrings (ie. 14T difference). While FD downshifts occur more-or-less instantaneously, I do find that FD upshifts (ie. 14->36T) can be a little ponderous sometimes. That's why I'd suggest that a 14-15T difference is close to the practical limit for reliable upshifting.
    Brisbane, AU
    Just Ride
    Reputation: Cormac's Avatar
    try removing the 32t ring and putting the 44 in it's place?
    SS ==> Nut up or Shut up!
    Hey, quick question about gearing. I, personally, am considering changing my 3x10 to a 2x10. Gearing with the triple is 42-32-24 with an 11-36 cassette. I'm wanting to get an XT 2x10, but the closest gearing to my current granny is a 39-26 crank. If I switch this, will I notice it being harder to pedal in my granny with the chain ring going up two teeth, from the 24 to the 26? I don't want to lose my climbing ability. Thanks.
    Quote Originally Posted by shawnca7 View Post
    your answer is here Sheldon Brown's Bicycle Gear Calculator .From 24 to 26, 2 teeth diff/24 t ring= 8.33percent harder to climb with a 26t ring. So, yes, on a difficult climb, you may notice that difference.
    your answer is here Sheldon Brown's Bicycle Gear Calculator .From 24 to 26, 2 teeth diff/24 t ring= 8.33percent harder to climb with a 26t ring. So, yes, on a difficult climb, you may notice that difference. Why not leave the 24, and just remove your 42t ring, change your 32 to a 39? You do not need to change your entire crank.
    Thanks for the info and the website. I'll definitely consider doing that.
