• Hello,
    This is my first post on MTB but I'm on the site quite a bit.
    I have a question about the bottom bracket setup on this bike. The bike was ordered directly from Devinci but it came to my lbs in a couple separate orders because they didn't have the bike in my size. So the lbs is building it up for me.
    My lbs mechanic is having troubles getting the Shimano XT cranks to work with the PF30.
    I have noticed on the Devinci specs it say the bb is a PF30 Adaptor.
    TECHNICAL SPECIFICATIONS
    FRAME
    CARBON DMC-G
    FORK
    FOX FLOAT 32 CTD FIT 29 100MM, KASHIMA COATING
    HEADSET
    CANE CREEK 40-SERIES ZERO STACK
    TIRES
    MAXXIS CROSSMARK 29X2.10 EXCEPTION SERIES HIGH TPI
    FRONT WHEEL
    EASTON EA70 XCT
    REAR WHEEL
    EASTON EA70 XCT
    FRONT BRAKE
    SHIMANO XT M785
    REAR BRAKE
    SHIMANO XT M785
    REAR DERAILLEUR
    SHIMANO XT M780
    FRONT DERAILLEUR
    SHIMANO XT M786
    FRONT SHIFTER
    SHIMANO XT M780
    REAR SHIFTER
    SHIMANO XT M780 10S
    CRANKSET
    SHIMANO M785 HOLLOWTECH II 40/28T
    BOTTOM BRACKET
    PF30 ADAPTOR
    CASSETTE
    SHIMANO XT 10S 11-34T
    CHAIN
    SHIMANO XT HG94 10S
    HANDLEBAR
    TVT NOIR T30 FLAT
    STEM
    TRUVATIV STYLO T30 31.8MM
    SADDLE
    SELLE ITALIA SL XC
    SEATPOST
    TRUVATIV NOIR T30 31.6MM
    SEAT COLLAR
    ALLOY CNC 37MM
    GRIPS
    DEVINCI PERFORMANCE W/LOCK-ON
    It seems weird that a bike from the factory would be using adaptors like WheelsMFG or others.
    Does anyone know the proper procedure Devinci would use for this XT cranks with PF30 setup?
    I can't get ahold of Devinci on the phone or email. I've tried a couple times.
    Anyways, I just thought I would put it out there hoping someone or a Devinci factory mechanic might come across this and have an answer.
    Thanks for any help
