Results 1 to 11 of 11
    Reputation: Dwhitt1981's Avatar
    2 DUMB Questions
    I think my rear derailer is bent. It's a sram x4 and I was thinking of upgrading it to a x7. Will I need to change the shifter also?
    I want to change to 2x front but I'm run 8 speed rear. Will I still have enough gears to pull my climbs?
    Former Bike Wrench
    A 9 speed X.7 will work with your existing shifters. The second question is really dependent on what gears you run up front and how strong a rider you are. Plenty of people ride 2 x 8 with no issues.
    Reputation: Nenbran's Avatar
    Dec 2010
    If you run 2 up front in the same fashion as most people, you will simply lose the big ring. It will not affect your climbing because you'll still have granny. I went 2 up front for awhile. It's easy to do; just replace the big ring with a bashguard and set the limit screw so you can't shift onto the bash.
    Are your X4 shifters 8 or 9 speed?
    The shifters are 8 speed but the specs I saw on the x7 said it was 8 or 9speed.
    As for the 2x up front I never get into the big ring unless I'm on a road ride.
    Former Bike Wrench
    Quote Originally Posted by Dwhitt1981 View Post
    It doesn't matter (though it seems obvious since you were asking about 2 x 8 that they are 8 speed)
    Just don't get the new 10 speed X.7, the 9 speed version will work with the 8 speed X4 shifters no problem.
    Cool sorry I was reading both posts and got mixed. Thanks
    Dec 2010
    Yeah, go with what mtnbiker72 says. The 9 speed should work fine.
    And yes, I rarely use my big ring. Only when I get to a long descent or a smooth flat.
    mtnbiker72 let me ask this. What do I need to look at to see if I have the extra room to upgrade to a 9 speed?
    Former Bike Wrench
    8 and 9 speed cassettes use the same width freehub body. So with a 9 speed chain, shifter, and cassette you can upgrade. The 9 speed chain will work fine on your 8 speed crankset and front derailleur.
    Cool thanks
  1. 2 dumb questions
    By Finch Platte in forum 29er Bikes
    Last Post: 08-20-2013, 08:14 AM
  2. Replies: 18
    Last Post: 05-18-2009, 09:41 PM
  3. More dumb questions
    By jacdykema in forum Vintage, Retro, Classic
    Last Post: 03-04-2008, 10:47 AM
  4. Dumb SS Questions
    By Ryan G. in forum California - Norcal
    Last Post: 12-31-2007, 07:09 PM
  5. (Dumb) BB7 questions
    By GRAVELBIKE in forum Brake Time
    Last Post: 01-20-2007, 09:28 AM
