Results 1 to 10 of 10
    bicyclist
    Reputation: fish man's Avatar
    1x9 for rough trails?
    On my 04 Trek 6700 i have a 44-32-22 fr and 11-34 rear, which i would like to switch to a single 34t ring in the front because i like it simple, i deal with a lot of mud and crap, my bike is too heavy, and i don't use the 22 or the 44 anyways. i have been hearing a lot about chain tension issues with this kind of setup... iwill be using a non-ramped chainring, but i'm going to be riding some pretty rough trails, and racing mostly too, so i want a no-fuss setup that will not derail. how to do?
    People who really know what happened aren't talking. And the people who don't have a clue, you can't shut them up.
    Tom Waits
    Reputation: Atomik Carbon's Avatar
    2 Options....
    I have been running this setup for over 2 years.
    First Option: Run a Rohloff chain guide. Setup is extremely critical. You need to drop the chainguide as low as possible without it hitting the crankset. You also need to run the minimum spacers in front and back of the guide, and not hit the chain. The front will have less space and the back more to accomodate the full range of the cassette.
    Second Option: Run a bash ring outside and a guide up against the chain so that it does not come off.
    Both options MAY require a chain tensioner like the MRP/LRP or the Heim guide if you are dropping the chain. Personally, unless you do a lot of rock gardens, you should be ok.
    Later Mon.
    bicyclist
    Quote Originally Posted by YaMon
    Later Mon.
    does anyone else make a guide like the rohloff? i can't get any info on their canadian distributor...
    Tom Waits
    Hazzah!
    I've been using a 1x9 setup for a few years also....Sram 12-26 cassette and an unramped 32t front ring, also using an Evil SRS guide. no shifting or chain suck issues ever...
    Sep 2004
    Bashring on the outside, N-gear Jumpstop on the inside.
    On MTBR hiatus :(
    While you're at it, switch to a medium cage (GS) derailleur or even a **gasp** short cage road derailleur.
    You don't need all that extra chain capacity and as a result you'll maintain higher chain tension and a quieter drivetrain.
    I built up a poor man's 1x9 that I rode for a season using a GS XTR RD, Spot chainring and no guides. I did drop my chain twice, but not where you would expect -- both times were while mounting up and just getting rolling.
    However, a Rohloff chain guide or the bashring / Jump Stop setups are both good advice.
    <img src="http://gallery.consumerreview.com/webcrossing/images/prime.jpg">
    bicyclist
    Quote Originally Posted by Speedub.Nate
    what are the cons then of a short-cage rd?
    Tom Waits
    On MTBR hiatus :(
    Quote Originally Posted by fish man
    Limited chain capacity for 27 speed drivetrains.
    Read >><a href="http://forums.mtbr.com/showthread.php?t=100049"> <font color="blue"><b> This Post </b></font></a><<
    bicyclist
    you're probably tired of answering questins about this, but from what i understand of your charts i wouldn't be able to go from 34:34 to 34:11 with a short-cage, right? that's my planned gear range, and its about what i need (ie i don't want to shrink it...)
    Tom Waits
    On MTBR hiatus :(
    Capacity wouldn't be the issue. Capacity requirements of your proposed drivetrain would mirror what's under the 44T column shown in the post I linked to:
    _______<u>34T</u>___
    1 - - 34 | <b> 0 </b>
    2 - - 30 | <b> 4</b>
    3 - - 26 | <b> 8</b>
    4 - - 23 | <b>11 </b>
    5 - - 20 | <b>14</b>
    6 - - 17 | <b>17</b>
    7 - - 15 | <b>19</b>
    8 - - 13 | <b>21</b>
    9 - - 11 | <b>23</b> <-max capacity req'd
    The stated capcity of an Ultrega SS (short cage) is 27T, well within the 23T needed by your 34 x 11-34T setup. (Remember: 34T is is both your largest and your smallest ring, so you only have to concern yourself with calculating differences across the cassette range).
    A problem <i>may</i> arise clearing the 34T cassette cog. Shimano states their road derailleurs will clear a 27T cog (jockey pulley to cog clearance), but that, too, is a conservative number.
    Search around the web and you'll find lots of examples of guys who clear 32T and some 34T cassettes using SS road derailleurs. I'm not sure what does and doesn't clear, but it seems that most of those who have tried it say it works and those who say it doesn't work haven't tried it. It may boil down to derailleur hanger length. Try it!
  1. USFS destroys MORE trails in Sedona!
    By Rollin'in'Zona in forum New Mexico
    Last Post: 05-11-2005, 07:10 AM
  2. Sedona - US FS destroys MORE trails!
    By Rollin'in'Zona in forum Trail Building and Advocacy
    Last Post: 05-10-2005, 07:25 AM
  3. USFS destroys MORE trails in Sedona!
    By Rollin'in'Zona in forum Arizona
    Last Post: 05-09-2005, 03:31 PM
  4. USFS destroys MORE trails in Sedona!
    By Rollin'in'Zona in forum California - Norcal
    Last Post: 05-09-2005, 09:04 AM
  5. USFS destroys MORE trails in Sedona!
    By Rollin'in'Zona in forum California - Socal
    Last Post: 05-08-2005, 10:34 PM
