Results 1 to 7 of 7
Thread: 1x9 question !
    1x9 question !
    hello can i fit this http://www.mountainracingproducts.com/mrp/1x/
    on octalink crankset ? what bolts do i need for single ring ? thank you !
    anyone ?
    meow meow
    Reputation: b-kul's Avatar
    you might be able to fit it but it would rotate at the slightest hit. id get the seat tube mounted one.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Quote Originally Posted by b-kul View Post
    What are you gonna hit it on?
    Unless you frequently hit your front derailleur area (never heard of such a thing) it's not a problem. The seat tube mount is primarily aimed at frames that cannot take the BB mount version (frames with press-in BB's, etc.).
    OP, the seatube mount definitely will work. The BB model may or may not depending on the particular BB. External bearing BB's usually have a spacer between the shell and driveside BB cup that the BB mount model takes the place of. Cartridge style BB's (like Octalink) don't usually have spacers nor a "lip" to provide a mounting point. E-type compatible BB's do. As for chainring bolts, all 1x models come with spacers that'll allow you to use your existing bolts.
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Reputation: boomn's Avatar
    Those guides work great if your bottom bracket can handle a spacer behind the drive side cup. One wit a lower bashguard can move, but those top only guides don't take the hits (or shouldn't unless you're very skilled at unique crashes). Octalink BBs aren't designed that way that I know of, so the extra thickness of the guide plate might prevent the non-drive side cup from properly bottoming out against the BB cartridge.
    thank you guys ! i will buy seat tube mount !can you suggest a good chainring ?renthal -e thirteen and others
    yup
  1. Replies: 7
    Last Post: 08-02-2013, 07:29 AM
  2. Forest City Trails Question: Sandusky Question?
    By bycyclist in forum California - Norcal
    Last Post: 07-26-2011, 11:43 AM
  3. Replies: 9
    Last Post: 06-02-2008, 09:44 PM
  4. Replies: 3
    Last Post: 03-07-2008, 06:41 PM
  5. Replies: 7
    Last Post: 03-17-2005, 02:19 PM
