    1x10 XT Conversion Questions . . .
    I'm shopping around for a crankset to complete my drivetrain upgrade to XT 1x10. I plan on getting the M780 3x10, which is $80 cheaper on Jenson than the M785 2x10, removing the three chainrings, and putting on a E-Thirteen guidering. My two questions are:
    1. Will I have any problems starting with the 3x10 M780, or should I go with the M785 2x10?
    2. I'm currently running a 32T middle chainring, but would like to change it to help out a little more on steeper climbs. I assume I should go up in teeth count for this? What are the benefits/drawbacks of going to 34T or 36T? I'll be running a 11-36 cassette, up from an 11-32 9-speed I'm using now.
    Jan 2009
    1. Should be no difference. Might be easier to mount a bashguard on the M780 though.
    2. You want to go down in tooth count to make it easier to spin on steeper hills. Unfortunately, 32T is about the smallest you can use with the 104BCD on the cranksets. Some manufacturers do make a 30T chainring but it is offset by a couple mm to clear the spider.
    If you cannot easily spin a 32-32, a 32-36 won't make a huge difference. It may be best to stick with 2x10.
    Thanks for the reply, acuracing. I went ahead and ordered the M780.
    As for the teeth, I'll just keep the middle 32T ring then. I'm actually already running a 1x9 with the Deore drivetrain that came stock with the bike. I never left the middle ring when I was running 3x9, and I don't know if it's psychological, losing some rotating mass, or me just continuing to get stronger the more often I ride, but my climbing has improved since making the switch. There's still two steep, fairly long tech climbs that kick my ass though, so I was hoping for a little added edge. Guess I'll have to conquer them the hard way.
    Thanks again!
    Reputation: Nater's Avatar
    If you find you want to go smaller than the 32, there are a couple manufacturers that are making 30 tooth rings that will fit on a 104BCD crankset.
    Wolf Tooth Components
    Race Face
    Or you could go with a SRAM X9 and use a spiderless ring from WTC, MRP, or North Shore Billet and go down as low as 27 teeth.
  1. Converting SLX 3x10->2x10 Crankset?
    By biggrumble in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-23-2014, 04:08 PM
  2. New Build: Start with either 3X10 or 2X10 for converting to 1X10?
    By marc927 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2013, 07:29 PM
  3. Converting a Stylo from a 3x10 to a 2x10
    By rcebowl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2013, 06:08 AM
  4. Thinking about converting 3x10 to 1x10 - Confused
    By SpecialJ in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2012, 09:33 AM
  5. Converting SRAM 3X10 to 2X10
    By Merost in forum SRAM
    Last Post: 09-18-2012, 11:19 AM
