1X10 my way vs XX1. What am I missing?
What will I miss if I run a 28t up front (xo crank) and an 11-36 rear cassette
vs.
XX1 gearing?
Will I just get spun out more on the DH sections?
**NOTE: I raced a 1X9 two seasons ago. I loved it, BUT I needed more low end on a couple of the courses.
It was a 32t and a custom 11X36 rear cassette. I am wondering if the new idea of running a 28t and an 11X36 will be what I was looking for two seasons ago.
Maybe I should get a 30t instead of 28t, but I am not sure a 2 tooth drop in the front will be that noticeable..
Ideas??
Being a racer you can probably put together some high cadence outputs which is what will be required on occasion with 28t. But usually that happens just to get started downhill, then coasting - and then mostly fire road or mach-silly trail.
I've run a 32 front on my Enduro for the last couple of years and have missed no gearing as I can do the quick high cadence burst to keep up or out in front of others.
I'll be going 28t on the front of XX1 (as soon as I can find the ring!) and 10s 11x36 like you.
I expect it will be a bit harder to top out, but then, usually, I am going faster than I should anyway.
P
What size are your wheels? I've raced with a 32t ring and a 11-36 cassette with 26" wheels... That gearing was too low to me. On my 32x11 tallest gearing, I was getting dropped on the start and was spinning way too much at the sprint finish. The steep climbs were fine, never felt out of low end, I was catching back people there... Now I have a 36t ring which is much better. Of course the perfect gearing depends where you race and how you ride (spinner vs masher). A 32t might work well on a 29er though.
Bookmark this gear ratio calculator, which allows adding wheel size as variable ( better and easier to use than Sheldon Brown link):
http://forums.mtbr.com/drivetrain-sh...4-0-a-8204.htm
For me personally on 1X10:
26" wheel = 32T; 27.5" = 30T; 29" = 28T
Obviously very subjective. YMMV
Old enough to know better. And old enough not to care. Best age to be.
So true.
And if you are racing on it, you need match your competitors or have a better gear set-up, less gear and be dropped
P
LT-5
Hey dwt, thanks for posting the link, but when I click there I get a "page not found"
 Originally Posted by Mr.P
So true.
P
Yeah, when I raced with my too small ring, it was just a local race I decided to do at the last minute, I was still playing around with the setup and I didn't had the time to make changes before...
Hmmm....Works on my iPhone
Try again:
Mountain Bike Gear Ratio Calculator V4.0
By PissedOffCil in forum 29er Bikes
Last Post: 01-30-2013, 02:53 PM
By TxMatt in forum Brake Time
Last Post: 12-19-2012, 05:36 AM
By Enduramil in forum Eastern Canada
Last Post: 08-15-2012, 07:28 AM
By zephyr11 in forum Knolly
Last Post: 06-18-2012, 06:22 AM
By savechief in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 02-07-2012, 05:13 PM
- You may not post replies
- You may not edit your posts
Forum Rules
