Results 1 to 5 of 5
    Dec 2014
    1x10 chainring spacing
    Recently changed out my SLX 3x10 to a OneUp oval 1x10 with a new 11-42 bigger cassette. I've mounted the 32t oval chainring directly to the crank but I'm thinking I should use the small spacers to shim it inwards towards the frame so there's better chain alignment when in the granny gears. Am I wrong or should I leave it as is? Basically the chainring is where the center ring was from the old 3x10 setup, unspaced.
    Reputation: J.B. Weld's Avatar
    The shims will give you better chainline which will reduce drivetrain noise and wear, I'd install them.
    I brake for stinkbugs
    Dec 2014
    Thank you! That's what I was thinking
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    I also use a Shimano 3x10 crank on my conversion, my chainring is already shimed by 3mm, even so I add one 2mm shim and also shimed my cassette 1mm outboard.
    When on my 40t and 46t cogs this extra shims make a big difference.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I believe that electing to shim towards those rear cassette chain rings that you expect to be using the most would be appropriate.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Chain line spacing for SRAM DM chainring
    By ghughes.hesinc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2016, 01:18 PM
  2. 1x10 chainring ?
    By Drewsj423 in forum General Discussion
    Last Post: 03-30-2014, 07:28 AM
  3. Crankset chainring spacing?
    By Pwshadow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-13-2013, 04:13 AM
  4. XT M780 cranksets -- double vs. triple chainring spacing
    By jabrabu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-06-2012, 10:48 PM
  5. Chainring tooth spacing?
    By dunerinaz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2011, 10:12 AM
