    Reputation: smokinoak's Avatar
    Aug 2010
    170vs175 crank arms
    O.k.,I have 170 on my bike right now,can I use the 175 if I have too,or should I stay with the 170.What are the differences?Mike
    Class Clown
    Reputation: dundundata's Avatar
    Well one is longer than the other. The 175s will get a little closer to the ground and a little higher on the top end.
    longer arm is also longer lever
    Quote Originally Posted by smokinoak View Post
    I am 5-11 I went from 170 to 175 quite a while ago...
    The first two weeks my knees hurt till they stretched out enough.
    Then it felt like I could finally take a full step on the pedal stroke.
    I had pedal strikes before I switched and I still get pedal strikes....it is all about technique anyways.
    I would not go back willingly to 10s.
  1. need help with stylo gxp crank, gap between cups and crank arms?
    By Rasterman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2014, 04:46 AM
  2. crank arms only?
    By super jim in forum Weight Weenies
    Last Post: 01-05-2010, 10:20 PM
  3. Crank Arms Stripped - New Arms or Crank?
    By mikelikebike in forum Beginner's Corner
    Last Post: 06-08-2008, 06:21 PM
  4. 175 or 180 Crank Arms??
    By CaliMTBR in forum 29er Bikes
    Last Post: 06-03-2008, 08:56 AM
  5. Looking for crank arms
    By Lollapalooza in forum Downhill - Freeride
    Last Post: 04-18-2007, 11:07 PM
