Results 1 to 9 of 9
    Reputation: KMan's Avatar
    120 BDC chainring options smaller than a 39t?
    I just recently switched my drive train over to a SRAM XO 2x10. 26-39t setup. I think for most of the trails I'm riding currently I could go 1x10 with a slightly smaller chain ring up front. Anything available 120 BDC in a 36, 37 or 38t? What I've been able to find drops to a 104BDC.
    Or will my only option be to switch to the XX1 crank set which has 34,36 & 388 ring options
    Michael
    Jun 2005
    warhawk spiderless chainrings
    Hi Michael, I have this exact crankset here at the shop and anything smaller then a 38T interferes with the spider arms. It is possible to space the chainring closer to the BB using 2mm spacers you just have to check and make sure the spacing doesn't throw off the chainline too bad. Problem is for about the same cost you could use one of our spiderless chainrings
    If we can help you in any way let us know, Thanks - Colin
    Warhawk Industries - Specializing in Stainless Steel, Titanium and Aluminum Chainrings
    Reputation: griffter18's Avatar
    Renthal do a 37t but I think that the lowest Ive seen
    Link:
    http://www.chainreactioncycles.com/Models.aspx?ModelID=92767&_$ja=tsid:46412%7Ccgn:Ch ainrings+-+MTB%7Ccn:Chain+Reaction-UK-PLA-PLA-Eng-DT-SE%7Ckw:358815UK_SR4+120+Ultralite+Alloy+Chainring
    MTB: Stumpy, Enduro, Hotrock, Commencal Supreme
    ROAD: Jamis Zenith, Pinarello Dogma
    There's always next year.
    Reputation: padrefan1982's Avatar
    Mar 2005
    My new Epic's got a Truvativ 38 x 26 teeth rings--and I love it. I'm assuming Spec got them made them. Watching this thread, as I won't want to go any bigger when I have to replace the ring.
    EDIT-- Did some quick searching, RaceFace does offer a ring at 38 teeth, found at Universal I've loved their rings in the past.
    No experience, but Renthal apparently offers them down to 36teeth, but no ramps... but I've run RaceFace singles on 2x9 before, so should work?
    Spec use custom cranks on a lot of bikes which means you may need to go to them for replacements where they are non-standard.
    Colin,
    Thanks - what is the difference between the Cyclone and Hurricane spiderless chainrings? I think this looks like my best option.
    Michael
    Quote Originally Posted by Warhawk View Post
    Jun 2005
    Quote Originally Posted by KMan View Post
    Colin,
    Hi Michael, just the designs are different. The cyclone grooves are machined with a flat bottom endmill in reverse to the hurricane grooves which are machined using a ball endmill, the cutouts are also different. Functionality wise they are the same were just trying to offer different design options. I do have a few other designs coming I just don't know exactly when I'll have them finished and up on the site yet. Let us know if you have any other questions, Thanks - Colin
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Wolftooth Components will be making a 1x10/11 120mm chainring very soon.
    From 32-38t, I think they said in another thread.
    Death from Below.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Le Duke View Post
    It is impossible to mount a 32T ring on a 120BCD spider (in the stock position). Can not use a 32T on a 110BCD.
    mtbtires.com
  1. What do I need for a smaller chainring?
    By Ryan The VW Tech in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2012, 12:27 PM
  2. Single chainring options?
    By Nockpoint 01 in forum Fat bikes
    Last Post: 09-26-2012, 08:25 PM
  3. Chain jumping gears..caused by smaller chainring?
    By Crash Dummy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2012, 11:32 AM
  4. Will changing to smaller chainring cause bashguard rub?
    By gddyap in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2012, 08:12 PM
  5. Chainring Options?
    By Ace5high in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-28-2011, 09:57 PM
