Results 1 to 32 of 32
    You won't take me alive
    Reputation: seachicken11's Avatar
    11/32 or 11/34 ???
    What are the benefits????
    Im interested, too. But Im pretty much settled on 11-34. It seems to have become the new standard.
    Whats interesting is that some say that by going 11-34, it doesnt "force" a rider to become stronger.
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Quote Originally Posted by seachicken11
    The benefit of 11/34 is that you get an easier granny to get you up steep stuff. The disadvantage is your spacing is further apart between each gear.
    The benefit of 11/32 is that your spacing is closer together so there isn't a big leap from gear to gear.
    I put 11/34s on all my bikes as I ride in steep terrain with climbs that never seem to end and I need the little bit of help a 34 tooth gives me over a 32. If you ride all the time you'll find yourself not using the 34 except on really steep terrain, so I don't buy the logic of keeps someone from getting strong. If you ride a lot you'll get stronger.
    Reputation: KRob's Avatar
    I just recently switched to 11-34 from 11-32 and so far I like it. I kinda thought I'd miss the 32 cog in back (it jumps from 30-34), but so far I haven't. I've found that I can leave it in the middle ring longer which is what I wanted. I was afraid it would be more trouble/finicky shifting up onto the bigger cog but it wasn't even an issue. Didn't even have to readjust the derailleur.
    I've got a couple of stupid steep, long climbs up in the high hills that won't be open until May that I'm looking forward to using the 34 on aslo. I can do them most of the time once I get in top shape... but just barely and one takes two or three rests and they always kill. I'm getting old enough that proving I can do it with a 32 cog isn't that important.
    Do It Yourself
    Reputation: Homebrew's Avatar
    Go with the 11-34. If you can get away with 11-32 you might as well upgrade to 8-speed. The 34T is the only possible advantage 9 speed has over 8.
    Long Live Long Rides
    OK, heres a new question on the subject, centered arounf the claim that I can stay in the middle ring longer.
    Its clear this is true. But by staying in the middle ring longer, wouldnt you then be running an extreme chainline more of the time and therefore be increasing wear and tear on components?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by SpeedThrills
    The drive line is under a great load, alot of people recomend replacing chains like 1-2 per year, sprockets & cogs 1 per year. I run a 22-32 & 11-34, front sprockets are 2 years old & look good, cog is 2 years old & looks good, chain is 1 1/4 years old might get a new on for spring. Either im a tender foot or just lucky .
    The devil is an angel too
    Mar 2005
    Well, yes, in theory. A 32-34 combo gives you a ratio of .94, to get a similar ratio with the granny ring -22T standard- you'd be running a 22-24 or so combo -for the sake of simplicity, I'm sticking to gear ratios, rather than gear inches.
    A 22-24 combo will give you a "extreme" chainline as much as a 32-34 one. So I don't think that the increased wear is going to be signifficant.
    Now, about 8spd set ups. The reason behind 9spd is not only so you can have a bigger spread -11 to 34 instead of 11 to 32- but also to give you more closely spaced cogs. By having more gears to select from, you are more likely to find the "ideal" gear at any given time. Is like putting more gears on a car, it is not give you a lower or higher top gear, is so you can more efficiently use the engine output. And you know who the engine is on a bike
    Not to downplay the "benefits" of 8 spd, or to argue about the real world necesity of a 9th speed, but, i t does go beyond having a lower gear.
    Quote Originally Posted by FrozenK
    I did a bit of reasearch on this...looking at what the ratios are compared to an 11-32. Ive found that often, matching my ratios from what I had on 11-32 would mean I go further IN (down) the 11-34 cassette to match a ratio I had on an 11-32 and would run a BETTER chainline more of the time. Youre actually in the center of the cassette more often with 11-34.
    So much for my theory (thankfully)......Im goin' 11-34.
    If this is true, why doesn't someone make a cassette with closer spaced lower (bigger)cogs? I'd love to have the lowest four go 28-30-32-34. I'd get a lot more use out of that, than the closely spaced higher (smaller) cogs.
    Reputation: shiggy's Avatar
    Dec 1998
    In 22+ years of mtbing I have never found the need for a gear lower than 24 x 32. My favorite setup used a 28 x 34 low.
    mtbtires.com
    Do It Yourself
    It is more extreme chainline but also distributes the load over more teeth. I've never found it to be a problem.
    Jan 2005
    Quote Originally Posted by KRob
    Politics
    Quote Originally Posted by shiggy
    nice. i figure you're younger and stronger than some of us here. i like 22x34 on some of the wicked climbs i encounter.
    - Giant NRS Composite - Giant XTC2 - Giant TCRCzero - Giant OCR1 -
    - nothing stock here - move right along now -
    - Geelong area, Australia -
    Jan 2005
    Quote Originally Posted by shiny_car
    He's up their with the rest of us old guys he just rides strange bikes & alot longer consistantly then some of us. Alot of time in the saddle .
    I was ok with 22 x 27 low but have gone back to MTB cassettes now which makes the 22t granny a bit pointless. I would probably like a 28 x 34 low as well but isn't a 29t ring the smallest you can go on a 94 mm BCD?
    Dec 1998
    Ike was president (2nd term) when I was born.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by eurorider
    I used a 28t inner ring on a 110/74 BCD crank, with a 44t or 45t in the middle position.
    mtbtires.com
    Oh ok. You would have needed a longer bb then if you wanted the 2 rings centered on the cassette. Or did you not bother?
    I've always thought 42t is large enough for a big ring though. Even Sauser runs a 42t and that's with a 12 -34 cassette. But I guess if you are bombing mountains...
    Dec 1998
    When you could still build your own gear combos I used bigger gaps between the big cogs and tighter on the small cogs. The percent of difference between the # of teeth remained fairly constant.
    I think a 12-13-15-19-23-28-34 was what I commonly used.
    mtbtires.com
    Dec 1998
    I used whatever spindle length was needed. Every crank required something different at the time. Still tended to run the chainline based on the middle ring as I only used the inner ring with the 2-3 largest cogs.
    My high was a 45x12. Considered low at the time. You saw lots of 48 and 50t rings with a 12 or 13 small cog.
    mtbtires.com
    Carpe Noctem
    Dec 2005
    When I used to race the course for at least two of the races and usually more started with 8 miles of climbing, some prety steep. I wouldn't use anything less than 12-34 and at the end of the season my granny would be shiny and unused. If you climb get the 34. Speaking of racing has anyone tried super d?
    Off season? What off season?
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Gotta Love The 50T Stock Big Ring!
    One of my XT 732 cranks came with a stock setup of 50-36-24.
    That 50-12 combo made for some fast fireroad runs to and from trails.
    exactly what I'm thinking
    I just posted on another thread here about how I like the 32-28-24 spacing of the 8 speed cassettes I have on two of my bikes as opposed to the 34-30-26 of my 9 speed ride. The gear spacing you suggest would be perfect for me given the steep sh!t I ride. It seems I'm always climbing climbing, which I actually love, and the extra close ratios in the upper range would benefit me more than 11-12-13 etc. I still wouldn't go into that 34 much unless it was at the end of a long ride with a killer climb to get back to my truck.
    Dec 2005
    The reason I went to 11-34 was so that I could run some bigger rings on the front and get some more high end speed, while still maintaining a nice low range.
    I did upgrade from an 8 speed cassette with 11-30 at the rear and 22-32-44 at the front, so running a 34-46 up front and 11-34 at the rear gave me a slightly easier gear low down and a slightly higher top end than what I was used to on my 8 speed gear. Dropped the granny ring altogether....
    MTB B'dos
    Reputation: LyNx's Avatar
    As someone who went from a 11-34 to a 11-32, I can tell you that there's a lot of "getting used to" the difference in gear sizes for where you are on the cassette. I still don't think I've gotten accutomed to it yet (had it on the bike for about 3 months, riden it about 7 wks of that). I find that I'm equivalently 1 gear harder if I run the same "gear" say 4 on it compared to the 11-34 and the legs haven't gotten back to themselves yet after December on the sick list.
    I prefer the 11-32 though since it allows you to shorten up your chain even more and as I did change from a long cage RD to a medium cage and help reduce chain slap.
    What sort of terrain you ride Shiggy, 'cause even though I like to be a power guy there are just some climbs - loose, very steep, rocky - that require the finese of a low gear combo and light spinning.
    Dec 1998
    Quote Originally Posted by LyNx
    ...What sort of terrain you ride Shiggy, 'cause even though I like to be a power guy there are just some climbs - loose, very steep, rocky - that require the finese of a low gear combo and light spinning.
    Oregon Cascades. Can be steep and loose and with long climbs. Plenty of places that require "finesse" climbing where I find too low a gear a liability rather than an asset. Can not modulate the power application as well.
    On the longer steep climbs using the lower gear gear hurts just as much but you are moving slower so it lasts longer.
    mtbtires.com
    MTB B'dos
    Don't know all the gradient angles/degrees etc, but I was refering to climbs along the 30-45+ degree angle and short coming maybe from a tech, slow downhill out of a corner type climbing - maybe I just still have some more to learn
    I agree using a lower gear gets to be a liability on long climbs and just makes it take that much longer - plus I can't really balance that well to stay in them gears.
    Dec 1998
    Don't know all the gradient angles/degrees etc, but I was refering to climbs along the 30-45+ degree angle...
    You are correct, you do not know gradients.
    You would have trouble standing on a 45 degree slope, let alone ride up it. A 30 percent slope on a trail is considered extremely steep and that is less than 17 degrees.
    30 degrees is about 58 percent which is Black Diamond ski slope steep.
    mtbtires.com
    MTB B'dos
    Where do you measure the percent/degrees from? I think of it from the horizontal towards the vertical. Just for clarification I'm going to use my HRM and do an interval up the slopes I'm talking about to get the elevation gain and the distance and from that get the angle/gradient. This way maybe I'd have a better idea of the slopes I'm thinking off. Oh and BTW I do have trouble standing on the hills I'm talking about and I'll stick to the fact that it's somewhere between 30-40 degrees.
    Dec 1998
    You are probably WAY overestimating the grades.
    Percent of grade is horizontal distance [run] (not the same as the distance traveled on the ground) by vertical rise. If a slope gains 30 meters vertically in 100 meters horizontally it is a 30% grade (~17 degrees from horizontal).
    A 45 degree slope is a 100% grade: 100 meters of rise in 100 meters of run.
    Go find a low wall or strong picnic table. Use a 2x8 plank to try differ grades. If the wall is 1 meter high, place the bottom of the plank 2 meters from the base of the wall. The resulting slope is a 50% grade (25-26 degrees).
    mtbtires.com
    http://www.cycle-dynamics.com/mtb.html
    Cycle Dynamics will roll you almost any combo out of ti for less than one might expect. Weights are comparable to XTR. I've only used their Campy 10spd cassette and it shifts quite nicely, as well as Record.
