Results 1 to 18 of 18
    Sep 2004
    WTF Truvativ DH rings dont fit on the hussefelt cranks?
    i just ordered an e 13 chainguide and realized that the DH ring does not fit in the middle position of the Truvativ crank, what rings do?
    Cynical Bystander
    Reputation: COmtbiker12's Avatar
    Quote Originally Posted by Richard85
    Which positions? They should be on the outer flange of the mounting area on the cranks. If you're trying it on the middle area then yea it won't fit.
    Tony
    is making a comeback.
    Turns out that five years of not mountain biking, really makes one strive to get back to it.
    Former Noob Herder
    Reputation: zedro's Avatar
    Quote Originally Posted by COmtbiker12
    yeah i hate that...why all my chainrings are filed down...
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Cynical Bystander
    Quote Originally Posted by zedro
    I more meant if he was trying to mount it on the granny ring mounts....
    Tony
    i run my ring on the middle ring position. it was a blackspire ring and fit perfectly without any grinding.
    Sep 2004
    yeah exactly im trying to mount it in the middle position
    Former Noob Herder
    man, you have less confidence in people than i do
    no, for some reason on alot of cranks (meant for multiple rings) the mid position on the spider has notches or something that makes the inner circle a bit larger (had this problem on my Shimano cranks). The solution: just grind off a small amount on the ring to make it fit.
    Cynical Bystander
    Oh okay. lol, im sorry i wasn't so confident in him.
    Tony
    Former Noob Herder
    i generally assume people know to not put square pegs into round holes....well most peeps here at least
    Sep 2004
    will the e 13 rings fit?
    Sep 2004
    Sep 2004
    will it ????
    Chillin the Most
    are these triple cranks your trying to mount this on? If that's the case, maybe think abouit getting a single driveside Truvativ DH arm from Truvativ instead. They do sell singles, if you order direct. If not well then I have no idea, all my Truvativ DH rings mount up on my DH Hussefelt and DH Hollzfeller cranks no probs.
    Former Noob Herder
    Quote Originally Posted by red5
    geez, a bastard file on the chainring will solve that, or dremel, or whatever.
    Zedro is right, I don't think I own a chain ring that hasn't been filed. It isn't much work and it works perfect.
    I had the same problem when I setup my old raceface prodigy cranks with a truvativ DH ring and a Mr. Dirt guide. Take Zedro's advice and buy a good file and file the ring down a bit. Or better yet, buy a dremel, or dremel-like tool, to grind the ring down. Chances are if you are into the DH scene you'll eventually need the dremel to jury-rig something up again.
    Simon
    Sep 2004
    i got it to work finally, i had to file down the granny gear mounts on the cranks and make the middle ring slot bigger to accomodate the DH ring
    Quote Originally Posted by DanD
    Hell I have to dremel my bash ring too most of the time to get it fit right.
  1. HELP..new FSA cranks OR quality rings for 952 XTR..OR 2x9
    By seatstay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2004, 10:19 PM
  2. RaceFace cranks, which rings fit?
    By ryan123 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-24-2004, 10:20 PM
  3. New rings for old XT M751 cranks?
    By Bike Nazi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2004, 05:35 PM
  4. Truvativ SS rings?
    By NuMexJoe in forum Singlespeed
    Last Post: 05-11-2004, 05:10 PM
  5. Does Diabolus X-type cranks fit to V10?
    By miqu in forum Downhill - Freeride
    Last Post: 04-25-2004, 03:53 AM
