Results 1 to 3 of 3
    Reputation: Xave's Avatar
    Will High Roller 2.7 fit an Orange Patriot?
    The question is in the title. Is there sufficient clearance?
    Or should I go for 2.5?
    I'll be using Mavic 823 rims.
    I use a Marz 66 fork.
    Glad to Be Alive
    it will fit the front easy enough
    probably fit back because those tires run small (not sure...but I bet they would)
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    do you like going slow?? because a 2.7 will make you slow in the rear.
    HARDTAIL PRIDE- 09 Kona Five-0
