What Does your DH Bike Weight? Post' em Up ! !
62K views 171 replies 94 participants last post by  KozSlow
#1 · (Edited)
:D :D
Just wondering how does your bike weight.
feel free to post a pic , your spec and setup.
:thumbsup:
#109 ·
17,4kg, 38,3 Pounds
Wheels: mavic 823 with hope pro II hubs
Brakes: avid code r
Cranks: Shimano Saint
BB: Race Face X-Type Team DH
Chainring: Shimano Saint 36T
Taco: E13 LG1+ (Truvativ XO if I can be bothered to take it from my Enduro)
RD: Sram XO
Shifter: Sram XO
Seatpost: Syncros AM
Grips : Odi Ruffian
Straitline Vertical Wedge stem
Cassette: Sram 1030
Saddle: WTB Silverado Team
Pedals: Nukeproof Proton Mag-Ti
Chain: Sram 1091
Bar: Havoc (will probably change it for a wider atlas FR at some point)
Fork: 36 Van Kashima 180mm
Rotors: Hope floating rotors
Headset: Some combination of a Ritchey PRO Logic and a Syncros AM
#114 ·
here is mine again, finally almost finished. waiting on some chainring spacers to install the chaiguide
it weights 38.8 lbs complete
BB7/SD7 brakes 203mm front and rear
manitou travis 180mm fork
Fox vanilla RC
race face diabolus cranks with MRP G2 chain guide.
transition revolution 32 wheelset
x9 shifter with x7 short rear derailleur
#120 ·
Bicycle tire Tire Bicycle frame Wheel Bicycle wheel rim
39.00lbs even
Frame: 2011 DHR size large
Shock: 2011 Fox DHX RC4 w/400lb steel spring
Fork: 2011 Fox 40 FIT RC2 w/green ti spring
Handlebar: Renthal Fatbar uncut 780mm
Grips: Renthal Kevlar
Stem: Function Inertia Project Fox 40 upper crown w/integrated direct mount
Brakes: Formula The One w/Goodridge hoses. F-203mm R-185mm
Shifter: Sram X9
Derailleur: Sram X9 shortcage, limited
Chainguide: e13 SRS
Cranks: e13 LG1 DH, 165mm
Chainring: Renthal SR4, 36t
Chain: KMC
Cassette: Ultegra w/1st, 2nd, 3rd gear delete
Pedals: e13 LG1 w/cromo axle
Wheels: Azonic Outlaw
Tires: Maxxis Minion 3c 2.5 w/tubes
Saddle: WTB Silverado w/nicro(?) rails
Seatpost: Thomson Masterpiece
Not done quite yet. Have plans to get Ti rear spring, upgraded wheelset, and possibly a bit of Ti hardware.
#122 ·
You guys running the lightweight air suspension on your DH rigs...are you noticing a decrease in performance? Are your shocks heating up on long runs? I'm just curious. Never really thought of running anything but coil for DH personally, but the new generation of air shocks/forks have me intrigued.
#125 · (Edited)
I guess I'll play. Been building up this slightly used frame with mostly spare parts I had lying around. I'm waiting on my new cranks to come in, but right now it's 35.12 lbs. I ordered some Truvativ Descendants and an e.13 guide ring. Assuming the weights are correct below and the manufacturer's weight for the pedals is correct, I should be right around 37.6-37.8 or so when it's finished. It's a large Specialized Status 1. We'll see if I'm right next week. :p
Crank Weight (Technically mine should actually be lighter with 73mm BB/spindle)
Ring Weight
I don't really care all that much because it's a downhill bike, but it's fun to speculate. Under 38 isn't bad with some midrange steel coil suspension and heavy, stout wheels with steel rear axle. I could easily build this up lighter if I wanted to, but I [personally] think this is a good mix of price/performance and weight/durability. If I was racing I might feel different, but this is just my play bike. :)
Current Parts List:
Rockshox Domain RC tapered fork
FSA Orbit Extreme Pro headset (reducer upper, 1.5 lower)
Black Market Underboss stem
Deity Dirty 30 bar
Black Market Lock-Down grips
Avid Code R brakes
Shimano Ice Tech rotors
SRAM X9 shifter
SRAM X9 rear derailleur
SRAM PG 990 cassette 11-34
SRAM PC 991 chain
Truvativ XO DH chain guide
Thomson Elite seatpost
WTB Laser V Team saddle with Ti rails
Azonic Outlaw wheels with Momentum stepdown rear axle
Maxxis Minion DHF 2.5 front tire
Maxxis High Roller 2.35 rear tire
#126 ·
Bicycle tire Tire Bicycle wheel Wheel Bicycle frame
My TR250 build ended out to be 17.08kg/37,65lbs in the end.
Should be starting on an Aurum build soon, should be around the same weight, but the Boxxer WC will save some I think, will also go for some lighter tyres and the frame might also be a bit lighter than the TR250.
#128 · (Edited)
Looks like I was right. 37.6. I'm pretty happy with that.
Current Parts List:
Deity Dirty 30 bar
Avid Code R brakes
SRAM X9 shifter
SRAM PC 991 chain
Truvativ Descendant Cranks with e.13 Guide Ring
Deity Decoy pedals
Deity Pinner saddle
#132 ·
bringing back this old thread,
i just finished upgrading everything on my IH yakuza.
it weights 42lbs.
specs:
Rock shock totem
diabulos stem
Fox vanilla RC
Funn fullon 7mm rise 750mm
Canecreek double X headset
demolition rob grip
red bar ends
fsa 30mm seat post
UGP RITZY seat
Raceface Diabolus Cranks hand polished
race face conversion kit
mrp g2sl mini chain guide
race face red 34t ring
cycletrack ck028 red pedals
Sram x7 rear der
Sram x9 shifter
Michelin DH 32 front 2.8 tire
saint 135x10 axle
hope proII hubs on Mavic ex729 wheelset
hope tech m4 brakes, picture shown M6 but swapped out for a new build
avid rounddagon rotors
