Results 1 to 27 of 27
    Reputation: jtnord's Avatar
    Jun 2010
    What to do with my Totem?
    Ive got a 2009 Totem SA that I picked up on clearance a few years ago. I have the Mission control damper with Low+high speed compression and rebound but it isnt the DH damper (I guess it was just called RC2). I took the floodgate out too. My ride weight is about 245lbs.
    The Totem has never felt great since day 1. It seems to struggle in the initial stroke and getting proper sag. It sticks a lot with poor small bump sensitivity. The mid stroke then feels good, not great. But then I cant get the last 1 - 1.5 inches with out dropping the pressure ridiculously low.
    I recently upgraded my frame to The One with a CCDBA. The CCDBA puts my Totem to shame for XC to DH.
    These are my options as I see them:
    1) I can send it in to SRAM for full service (it needs it) and DH cartridge upgrade
    2) I sell it for cheap then buy a new 2013 model RC2DH
    3) Send it to Avy
    4) ?
    What should I do with my Totem?
    Thanks in advance!
    6'5" 230lbs
    My Build: Vitalmtb - Bike Check
    Flacko
    Mar 2006
    send it to avy
    Jan 2009
    either get a newer fork, 2013 model or avy it...
    Biking Like Crazy!
    Reputation: blcman's Avatar
    Never had good sensitivity with my Solo Air either, and it had the DH Mission damper. Sold it to a friend.
    I have an 2011 Totem coil with the regular Mission damper and it works better. I have to use the lighter spring than calls for my weight tho.
    You could try converting the SA to coil. I'm sure the Avy would make it better but the air piston stiction is most of the problem.
    2017 Niner Rip 9 RDO Pushed Version!
    2015 Ibis HD3 w/ Push ASC3
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    Reputation: nobrakes2007's Avatar
    Dec 2010
    Either convert it to a coil or send it to avy. I have a 2010 coil on a Knolly DT and use that bike probably very similar to how you use your The One. It is going to be a little heavier with the coil but the difference in feel is great. Food for thought....
    Jun 2010
    Thanks for the responses everyone! Im trying to avoid adding weight but coil sounds like the only option if I stick with a Totem. Conveniently Marz isnt making the 66 anymore (at least temporarily) or I would pick one of these up.
    In exploring all options, would anyone do XC/AM with a Boxxer WC or the new 40 Float? The impact on geo would be minuscule and they are only a little heavier than the Totem. Is there a noticeable difference in turn radius between the Boxxer and 40? Ive only ever been on Boxxers.
    6'5" 230lbs
    55 RC3 Ti @ 170mm. That will have you smiling for all type of riding and light as hell for a coil.
    I had a Totem SA and felt like I really had to ride it hard to get it to open up for AM riding.
    Much prefered my Marz 66. I tried to run a totem coil for a bit, but it was DOA, had an oil migration problem.
    Just got my first ride on a new rig with a 888 - I can say the turn radius would be a problem!
    So, when I was in your shoes, I talked to craig @ avy - he said to:
    1. put a coil in it. there is no substitute for a coil if you are a bigger rider. air is inherently a trade-off between small bump and bottom out.
    2. if the coil didn't solve my problems, he'd custom tune it.
    Reputation: ryan_daugherty's Avatar
    Quote Originally Posted by jtnord View Post
    Based on what i understand XC/AM to be then no i wouldn't. I wouldnt ride a dual crown for anything but DH/Park.
    Huffy Rider
    Reputation: motochick's Avatar
    Jun 2010
    Coil+Avy cart. It won't matter what year the fork is if you go this route, you will have a much nicer set up that is custom valved for your weight.
    Reputation: trailbildr's Avatar
    Dec 2004
    How about servicing it. Have you ever had it rebuilt? I see forks that need to be serviced when they are brand new. Two weeks ago I rebuilt a brand new Fox 32 on day one because it felt terrible.
    You can spend $80-100 getting the fork serviced to see if it still is no good. I have the same Totem and really, really like it.
    Take it to your local suspension-friendly shop. If it's re-built, it'll be easier to sell if you go that route.
    Good luck. Let us know what you do.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Biking Like Crazy!
    Quote Originally Posted by trailbildr View Post
    mk
    Good advice trailbidr. But I think the OP's problem is his weight (no offense OP) and air suspension don't work well
    when you have to add a lot of air for proper sag, hence coil will work better. At least that's what I've told by Craig at Avy.
    You said you have good success with your SA. How much do you weigh if you don't mind me asking?
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    meow meow
    Reputation: b-kul's Avatar
    avy all the way.
    Jun 2010
    mk
    Ive changed the oil 2x and buttered it up but I do need a rebuild thats what triggered this dilemma. There are no shops around that are suspension friendly. The shop I favor will send it in for the rebuild but it will cost about $150. For that amount of money I dont know if it's worth it.
    Quote Originally Posted by iguanabartola View Post
    Might consider it. How is the stiffness? Im quite heavy. Can I get it in 1.5 straight steerer? From the Marz website it doesnt look like an option.
    Quote Originally Posted by CharacterZero View Post
    Yeah I wouldn't have to think about this if I could pick up a new 66 rc3 evo ti with 1.5 steer. Im not in a hurry to go with a coil conversion and add that much weight but not out of the question.
    Thanks for all the help guys!
    6'5" 230lbs
    I know everyone has different preferences, but at 230lbs, you shouldn't use 1lb of weight difference to justify not running a coil, you are strong enough for it to not matter and heavy enough that you'll notice an immediate improvement in ride quality. It really is that simple.
    Jun 2010
    I rode a 37lbs freeride bike with 36 spoke outlaws (2440g claimed weight) for XC for 1.5 years. It sucks. Ive spent a lot to get this new bike down to 34lbs even. So no, Im not in a hurry to add 1+lbs although it is most likely the route I go.
    6'5" 230lbs
    Dec 2004
    Where are you at? At 230, you are certainly pushing the design limits of products. A Totem is an xc fork for you, for sure. The change-over to coil isn't crazy expensive (I don't have it off-hand) and you can always go back if you don't like it.
    I get the feeling it's not the damper causing you drama, but the spring rate of the air spring in that fork. I've asked the boys what the delta is between the coil and air spring and will let you know when I hear back. If you aren't getting the last 1.5" of travel, it's hard to say what is causing that other than the spring. You could try lighter oil in the damper but I just don't see that really doing it for you.
    Keep us in the loop.
    mk
    TrailWerks Cyclery
    Reputation: rdhfreethought's Avatar
    Where are you at? At 230, you are certainly pushing the design limits of products...
    Actually he is 245lbs RTR
    I would echo the statements of others here. If you are in the 'I want my bike at light as I can' boat. Then you need to have the mentality of picking products that are as strong as you need, but also light. This brings back the "Strong-Light-Inexpensive...pick any two" truism. If you already broke the bank, that's fine. It just mean the upgrade will come in a few months when you save enough money. There are improvements with each year, some are cosmetic, but many are actual engineering improvements.
    My advice: think about what is the minimum strength range you need for a product. THEN look at the cost-no-object market. THEN fine a buddy, or local shop that has that item in stock, and test it. You will find that things feel different at your weight, flexy, or poorly damped etc. Don't limit yourself to 'I don't like x-product, they are jerks/bad CS etc'. I may not like the elitist attitude of Fox shox, but I think they make some of the best air shock products out there. Remember your basic physics, a 180mm fork with the same stantions will be more flexy than a 160mm fork. I have both Float 180 and Float 160, and am happy with both.
    I think you will be able to find a low weight fork that works for you. You may need to change oil viscosity from 5wt to 7.5wt or higher, or oil volume, or aftermarket damper/seals. But, again it will probably be "Strong-Light-Inexpensive...choose two".
    Regional Race Manager, Knolly Bikes
    Washington, Oregon, Montana, Idaho, Wyoming
    Huffy Rider
    Jun 2010
    You CANNOT change back from coil to air. Once you install the spring, it bangs around on the inside of the tube, scratching the surface, and the air piston will never seal again. At your weight, coil is the way to go. Think about it, I run my Totem air at 40PSI, the damper is under about 20lbs of pressure while it is working.....so right off the bat, my damper is having to work against the 40lbs of pressure from my air piston. Imagine how much more air you would have to run and how much that damper is fighting against the air pressure. With the coil, there is nothing under pressure. Good luck in your quest.
    RideDirt
    Reputation: aedubber's Avatar
    Go coil , send it to Craig @ Avy , have him work the magic . The outcome is so worth it , im only like 190lbs now and i will ONLY ride coil ... I even did it during trail riding etc... Coil is the only way !
    Biking Like Crazy!
    Hope
    Hey jtnord.
    One thing you could try is to shorten the air piston shaft to give you more air volume.
    It's a mod that is widely used on the Fox Floats to give them full travel and small bump sensitivety.
    Check out the thread on this forum for more info.
    Fox air forks - Modifying volume to get full travel?
    Just another thought.
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    Dec 2004
    Shrink wrap the coil to keep it from banging against the inside of the stanchions. That's your old hope of going back to air from coil.
    mk
    TrailWerks Cyclery
    I hear you, rode a 38lb Delirium for about 2 years, went back and forth between the Totem Solo Air and Marz 66. Rode it AM here in Austin, switched stem and wheels and took it to NM and CO for lift duty.
    I ended up splitting up the stable this year (Chilcotin and a Status) and am sure that having the appropriate tools will keep me happier...but I'd build a ONE in a heartbeat.
    Jun 2010
    Quote Originally Posted by blcman View Post
    Hey jtnord.
    Hey thanks for the link! I found it interesting and learned a few things. Im not sure I can really use that mod with the Totem as it uses a different system. If there is a mod for the Totem beside removing the floodgate on the damper please let me know.
    Im going to try to take out a few ml of oil from the damper as Im pretty sure I'm slightly over. Im not sure this will make much of a difference though.
    6'5" 230lbs
    Jun 2010
    Quote Originally Posted by rdhfreethought View Post
    Strong + light. I never mentioned price other than to say Ive spent a lot to lighten my bike so I dont want to rush into a conversion that will add 1+lbs.
    I think a 180mm 36 might be too flexy for my liking and I want a 1.5 straight steerer if I go with a long travel single crown. Newer models dont seem to come with the 1.5 straight steer tube option.
    6'5" 230lbs
    Jun 2010
    Why did you switch back and forth between the Totem SA and Marz 66? I would think the Marz is hands down better at a marginal weight increase? Or was it the non Ti 66?
    6'5" 230lbs
    it was the Ti version, but I didn't buy the Ti version specifically for the weight aspect, I just found a smokin deal on it. I only had the SA version of the totem because dropnzone had a great deal on it when I bought my delirium. I don't really shop for weight (ha, as a matter of fact, I've got a coil lyrik sitting in the garage waiting for me to move over my avalanche cartridge from the lyrik air i'm on, as the air just isn't quite right for me).
    Well, I grabbed the marz when the totem had to go in for some warranty stuff. They fixed it and sent it back. I ran the totem again for a while, but had been spoiled by how buttery smooth the marz was. I went back to the totem and no amount of adjustments could get it close, then I dropped it by a buddy's that was a SRAM authorized mechanic only to find that it had oil migration out of the box, hence the small bump compliance issue. Back to the marz, and meanwhile SRAM sent me a Totem Coil RC2DH to run. Well, about that time the FR bike went to its next life and they were both sold.
    All in all, the Totem SA worked best in CO and at the resorts where the speeds were higher and the features were bigger. For local riding (AM style in the techy/rocky/rooty hill country) I really had to ride it hard to get it to open up, which was motivation to go faster, but it also just didn't feel that great. I very rarely saw bottom out in local riding.
    The marz was perhaps even a bit undersprung for my weight with the preload maxed out, but no additional PSI. I had a couple hard bottoms (as would be expected on a 4' to flat drop), but otherwise, the thing was just super slick buttery goodness. I picked up an 888 RC3 on the Status and it doesn't quite feel as good as that 66 did (yet, I hope to get it there!). But when that 66 was on rocky/rooty/techy stuff up or down, it was great. Simple, predictable and matched the ccdb out back very well.
    hope that helps!
  1. rs totem or fox 36 van r
    By reformado in forum Transition Bikes
    Last Post: 06-03-2012, 11:51 AM
  2. Totem - Deville
    By spooney in forum Shocks and Suspension
    Last Post: 02-12-2012, 07:28 AM
  3. Totem or 66
    By vpc-los in forum Downhill - Freeride
    Last Post: 07-12-2011, 10:16 AM
  4. totem getting warrantied.....
    By SamL3227 in forum Downhill - Freeride
    Last Post: 05-14-2011, 01:52 PM
  5. Totem changes
    By macming in forum Shocks and Suspension
    Last Post: 01-13-2011, 10:18 PM
