Results 1 to 21 of 21
    Tire pressure for DH
    What tire pressure do you run on?
    Reputation: daisycutter's Avatar
    25psi for Maxxis Dh 2ply tires
    RideDirt
    Reputation: aedubber's Avatar
    Depends
    Reputation: highrevkev's Avatar
    Too many variables to give you a direct answer.....Depends on your weight, riding style, terrain, tire/ tube setup, etc.........
    PMP,TAN,LAUNDRY
    Reputation: azdog's Avatar
    25*25 tubeless ust. minions on 823's.
    Bender to AZDog: I'm not the best person to give advice on not riding!
    Downhill fan
    Reputation: #Cyclelife's Avatar
    True about the variables when setting up tire pressure. Trail conditions dictate my tire pressure changes. I run mine low. 17-22 lbs on my Kenda Nevegal stick e's. I weigh about 165 lbs and have never flatted a DH tire LOL. Smoothness is the key. Now, the XC/trail bike is a different story but I do things with that bike I shouldn't haha. Tire pressure on that bike is usually 22lbs give or take a pound or so. I run tubes with all my rides.
    I'm thinking about shreddin' it up right now!
    Giant Glory DH (custom)
    K2 Evo 4.0 FS XC (custom)
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    by feel
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    Reputation: monkei's Avatar
    I seem to pinchflat doing DH if I run much less than ~30psi. I run minion DHF/DHR 2.5s w/ tubes. I'm not even that friggin heavy (~160-170lbs)
    My bike video YT channel: biiiiiiiiiiiikiiiiiiiinnnnnnng
    ventanakaz
    Reputation: 1962's Avatar
    I run 20lbs up front with nevagal 2.7 and run 25lbs out back with minion dhf 2.7 of course this is on wide DH rims. The more narrow the rims the more chance of pinch flat, so you'll have to up the psi...ralph
    i need to ride more. building jumps takes to much time...my other hobby is kicking the crap outta my home built mook jong.
    Jan 2009
    i run my tires hard, 40 psi,, if i go lower i seem to pinch flat, and thats with dual ply dh tyres to. im not very heavy either. 64kg. roughly 10 stone, think thats arround 140- 150 lbs, and i wouldnt say im an agressive rider either. im quite smooth. lol.
    Aug 2005
    Heavy tubes with PSI between 22-27. Higher PSI if its drier, less its wet.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    28 psi, or lower it until you start pinch flatting, then go up 2 psi.
    Antitheist & Kitten lover
    Reputation: jasonvelocity's Avatar
    No flats, I always run tubeless.
    30 PSI in my Minions.
    Race Mojo Wheels | Read VitalMTB
    Perpetual Hack
    Reputation: mykel's Avatar
    220lbs
    Knolly Podium w 888RC3Ti/CCDB Coil
    DTSwiss 600's
    Basic lift service trails - flow, berm, jump or tech rock and roots...
    Front- Schwalbe DH 2ply Vertstar Muddy Mary 2.5 / Big Betty 2.4 @ 26-27lbs
    Rear - Schwalbe DH 2ply Vertstar Big Betty 2.4 @ 29-30lbs
    michael
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    Quote Originally Posted by 1962 View Post
    ...of course this is on wide DH rims. The more narrow the rims the more chance of pinch flat, so you'll have to up the psi...ralph
    What width do you consider wide? I'm running dt 6.1d in the rear (32mm outer width) and can't seem to find much wider rims (not built wheels) that are meant for DH/FR.
    I weigh about 220, and run Continentals Kaisers 2.5s 2 ply, wire bead (non-UST), without tubes, using Stans on DeeMax wheels at about 17 to 22 psi. Ive run 2.3 Butchers at about the same PSI.
    The guy yo' momma "act" like she don't know!
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Usually around 30psi, 205lbs.
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    If I run anything lower than 30psi my tires roll in corners, bad.
    30f/35r, 99% of the time.
    I'd rather have a bottle in front of me than a frontal lobotomy.
    Running on ITS edge 2.35. Tire says 30 - 60psi... Any issues running below 30psi?
    Perpetual Hack
    nope.
    inflate to about 40 lbs - this seats the bead.
    Drop pressure to what is required by your riding.
    You can drop the pressure until you start to feel roll the tire over, or pinch - at this point add 2 lbs and try again.
    Every tire has a sweetspot as far as a balance of grip and pedalability. With a bit of experimentation, you will be able to find this spot.
    ..and unless you are a clyde or a pro, most of us end up running the pressures below what is stated on the sidewall.
    hth
    micheal
    Hatched in 1964
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    ventanakaz
    Re: Tire pressure for DH
    Quote Originally Posted by monkei View Post
    ...I build my own wheels and the reason being is a long time ago I stopped trusting shops to build my wheels, they would never hold up. as for the rims I have their atomlab DH rims and I'm pretty sure you can get rims wider than 32 mm but i've been outta the loop for a few years...ralph
  1. 29 Tire pressure
    By Iam2of4 in forum 29er Components
    Last Post: 09-25-2012, 08:25 PM
  2. Tire pressure help
    By CabinDweller in forum Wheels and Tires
    Last Post: 05-09-2012, 04:17 AM
  3. tire pressure
    By spartus625 in forum Beginner's Corner
    Last Post: 05-02-2012, 04:04 AM
  4. Tire Pressure ?
    By rickcin in forum General Discussion
    Last Post: 07-11-2011, 12:18 AM
  5. Tire Pressure
    By AllisonWunderland in forum Beginner's Corner
    Last Post: 06-20-2011, 05:49 AM
