Results 1 to 20 of 20
    Reputation: Michaelsvx's Avatar
    Feb 2017
    Time for new brakes
    I like to replace my current brakes with something affordable and comparable to what I have now. I have a background in bmx and flatland so please forgive my ignorance. I have no idea how to spec new ones out. Any help is appreciated. Time for new brakes-img_9471.jpgTime for new brakes-img_9472.jpgTime for new brakes-img_9473.jpgTime for new brakes-img_9474.jpgTime for new brakes-img_9475.jpg
    Unsure of your budget but Shimano Zee would be a good bet. If the rotors are the same size front and rear they're 203mm IS-6 rotors. Shimano Ice-Tech would be what I'd run.
    Feb 2017
    Quote Originally Posted by PUNKY View Post
    I was hoping for under $200 idk if that's possible. I'd even consider used
    Reputation: Dougal's Avatar
    That rig should be kept intact and together. It's a classic.
    Your fork is 99 vintage and those brakes are possibly 69mm spacing which isn't compatible with anything else. Your rear adaptor could be swapped by the front can't.
    Those Hayes mags still work great. I still run a set.
    Sent with 100% recycled electrons.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    Feb 2017
    The backs aren't releasing properly slowing the back wheel. I'm looking into a rebuild kid but I'm afraid it won't work right when I put it back together. Like I said I have no idea what I'm doing. I have bleed car brakes so I'm hoping the same principles apply
    Feb 2017
    Thanks for that useful info about the spacing. By spacing are you talking about mounting holes or rotor offset alignment?
    Feb 2017
    I just realized Dougal you have been helping me with my shock seals. Thanks for that as well. I'm waiting till Wednesday to order and I'll be keeping everything together assuming I can get that caliper sorted out.
    Quote Originally Posted by Michaelsvx View Post
    They need bleeding and resetting. Best results are to pop out the pistons one at a time (remove pads first and put somewhere safe) then clean/grease the piston and seal before reinstalling.
    Bleed them by pushing fluid uphill from the caliper to spill out the lever, make sure the pistons are retracted flush with the housing.
    Then you should be good. Apart from lever wiggle these are still competitive brakes.
    It's the caliper bolt spacing to brackets that changed. Pre 2000 was 69mm (actually 68 or 71mm). 2000 onwards was 74mm. Looks like your rear is a 74mm and front 69mm.
    SPV Devolve
    Glad to Be Alive
    I wouldn't get new brakes just bleed them...if they still stick then take pistons out, clean them and put new o rings (moisten the o rings) and put pistons back in.....keep away from everything else because brake fluid is not good and will contaminate your pads...clean with rubbing alcohol after...
    Quote Originally Posted by SHIVER ME TIMBERS View Post
    There are greases specifically made for lubricating brake seals and pistons. I can't help you out with brand names though as the one I use is a small local brand.
    SPV Devolve
    Glad to Be Alive
    you are right but I have just used the fluid.....and never had a problem ...now I am wondering...but the same brakes are 5 years old
    Reputation: Seventh-777's Avatar
    Aug 2013
    Unless you're going balls out down steep stuff constantly, a set of XTs is within your budget and will be a solid upgrade for you. I ran my enduro bike at Highland for half a season this year (before picking up a proper DH bike) and XTs/IceTechs held up great for a dozen or so trips to the mountain - just had to change pads.
    I'm going with the Zee set on my DH bike now, but only because I don't go hard enough to justify a set of Saints.
    Trail: Scalpel-Si / Sherpa / Fatboy
    Gravity: Nomad / Wilson
    Road: Stigmata / Slate
    "Aah the great indoors - No One Ever"
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    I would rebuild them over replacing. They fit the bike and i'm a sucker for original complete bikes.
    If you do replace zee or xt would be your best bet.
    Quote Originally Posted by Seventh-777 View Post
    Did you miss the whole discussion about 69mm brake mount?
    Shimano don't make anything that will fit.
    SPV Devolve
    Reputation: nauc's Avatar
    if pistons are sticking, they probably just need cleaning
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    it's very easy to replace the Pistons.. and cheaper than brand new brakes
    Hayes Caliper Rebuild Kit - G1 & G2 | Chain Reaction Cycles
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    Feb 2017
    Shwinn8 thanks for the link. I just placed my order. Hope this goes smoothly
    Feb 2006
    I'm sure there's a YouTube video to assist you in
    '11 Jedi
    Dec 2012
    interesting that this was just posted on Pinkbike, maybe it will help you: https://www.pinkbike.com/news/tech-t...ol--video.html
    Sep 2017
    i had a set off zee brakes myself and say they would be a good shout for a replacement, would have a set of them myself still if it wasnt for the fairly new hopes
    Ross
  1. Hard time adjusting the brakes (disc-brakes)
    By Miika1983 in forum Brake Time
    Last Post: 08-06-2016, 07:42 AM
  2. Long(ish) Read - Time for a New Bike - Decision Time
    By mmckechnie in forum Specialized
    Last Post: 04-24-2014, 06:43 PM
  3. Spring Time = New Podium Time!
    By Buzz in forum Knolly
    Last Post: 03-21-2012, 07:16 PM
  4. Replies: 10
    Last Post: 06-16-2011, 12:09 PM
  5. Time for new brakes?
    By jeffmuldoon in forum Brake Time
    Last Post: 05-13-2011, 06:43 AM
