Results 1 to 37 of 37
    e.f.f.e.c.t smoothoperatr
    Reputation: themarsvolta55's Avatar
    Dec 2004
    Caution;  Merge;  Workers Ahead! tech? making a integrated stem
    yozz
    cause im into this stuff, i want to make a integrated stem for my 06 boxxer. i dont want any comments of "just buy one" cause its good to get the hands dirty and do it yourself. me and my friends got the machines, bridgeport mills and lathes, couple questions. what kind of material ( alluminum). is it all 6061 alluminum? if not, what kind. any other tips, other then to check 4 times, then cut
    thanks
    Reputation: karpiel666's Avatar
    Jan 2005
    I am also inerested as I want to make a new top crown with intergrated stem for my 01 monster t
    Quote Originally Posted by Qatarbhoy
    I have to ask for them to do a "Number two" on my head
    Dr. Bike
    Mar 2006
    Typically they use 6061 aluminum in those applications. Not that you would need to know this for a stem but a welder told me 6061 is much easier to weld than 7000 series aluminum.
    I agree with you about being fun to make things yourself. I'm a machinist and have made all sorts of things for my bikes.
    If you make something idiot proof, someone will make a better idiot !
    Dec 2004
    Quote Originally Posted by david101372
    i wont be welding, that would be to sketchy for me for a stem
    im milling it from a block
    pwn3rator
    Reputation: scabrider's Avatar
    go with 7000 sieries aluminum (7075 is best) if you wont be welding, it will hold up better over time and is much harder than 6000 sieries. when you make the part for your bars to go through, drill the hole the same dia. as the bars and then cut that sectoin in half, giving you the bar clamp. the drill and tap yor bolt holes and finally mill about .100 to .150 off each side on the inside (the side that the bars touch) so you can clamp the bars firmly. also i would go with a sinlge piece like the marz. integrated stem instead of the two piece ones e.13 makes for boxxers. that's about it, anymore explanation would require pictures. i could make you one, $83.00/hour is the shop rate...
    SOCAL UNION REPREZENT
    Quote Originally Posted by JBsoxB
    does it still qualify as a mountainbike?
    Quote Originally Posted by kidwoo
    I've beat beer cans on my limp pee pee.
    Dec 2004
    Quote Originally Posted by scabrider
    yeah im gunnu make a single peiced one
    i was thinkin of the same process with making the bar clamp, good stuff, 15 hundreths of an inch?
    pwn3rator
    150 thousanths...
    Dec 2004
    150 thousanths...
    gah thats what i thougth, i suck with decimels
    Reputation: Amazing Larry104's Avatar
    Aug 2005
    i dont think scab rider know wat hes talking about
    i designed this one. u dont kneed and tools to take out the bars
    IS THIS SOMETHING YOU CAN SHARE WITH THE REST OF US AMAZING LARRY ?!?!?!
    aircooled VW FTW
    Quote Originally Posted by Amazing Larry104
    And you do? Wtf is that.
    Road/XC/Freeride
    Reputation: Ace1's Avatar
    ROFL surely the bars are just going to spin like crazy in that thing.
    Also, what's the point - not many people do trailside handlebar swaps and even if they wanted to - carry a multi-tool?!?
    Sorry, don't mean to sound demeaning.
    I'm on the Twitter.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    you 2 are obviously dorks, the stem above is as real as they come. larry made me one about a month ago and the thing works flawless.....
    Road/XC/Freeride
    Quote Originally Posted by .WestCoastHucker.
    lol, I'm not a dork - can't vouch for Kjcorley
    Pretty surprised, want to see a pic of this! Cummon the pic's hardly a precise CAD.
    What was the reason for creating a tooless stem anyway?
    I'm on the Twitter.
    Quote Originally Posted by Ace1
    My thoughts exactly.
    If your gonna try and convince me that you made it or that you could make it, at least upload a decent cad drawing and rendering not a dinky picture made in paint. Not to be hatin or anything, just don't go dissing what scab rider is saying (he seems to know what he is talking about) and then try and justify your special stem with a drawing that looks like a joke. If it's real though, I'd love to see a picture.
    Pro Crastinator
    those were the prototype spy pics.......
    Dec 2004
    amazinglarry is in trouble, he was not supposed to release those until the end of this season someones getting fired.
    notabouttoseeyourlight
    Reputation: coma13's Avatar
    cycle tracks will abound in utopia.
    Equal opportunity meanie
    Reputation: DHidiot's Avatar
    I milled out an integrated stem for my '05 Boxxer a while back (no longer have the fork but kept the stem). It came out very well and lasted much longer than I thought it would and didn't fail. If you use pre-heat treated 6000 series you should be fine. I believe I used 6061-T6.
    The hardest part I ran into was making the cut for the handlebars. Since we didn't have any stock sitting around that was thick enough and wide enough to cut it out of one piece I had to make two, cut the bolt holes and threads, then did a 1.25" endmill plunge through the stem with it already bolted together in the vice with a 1/10" spacer between the pieces for the offset. The problem that comes from this is that you will probably not have an endmill that is long enough to go all the way through with out hitting the collet, so you may have to run it a 1/4" - 1/2" out. Conveniently enough though, handlebar diameters are exactly the same as your 1" and 1.25" endmills so you won't need a bore tool.
    I'll find some pics of it soon and feel free to PM me if you want any other details.
    Scabrider, 150 thous is the same as 15 hundredths....I wouldn't be paying you any $83/hour for machine work....
    Glad to Be Alive
    URL]
    no....he does, been milling stuff a lot
    Aug 2005
    Quote Originally Posted by SHIVER ME TIMBERS
    so have i
    aircooled VW FTW
    Oh, So Interesting!
    Reputation: davec113's Avatar
    go with 7000 sieries aluminum (7075 is best)...
    Yes, its about %75 stronger for what you'll use it for over 6061. 6061 is NOT a high stregnth alloy, if you copied current integrated stem designs made from 7000 series w/6061, it would probably fail.
    You might want to check out Romic's top crown/stem design, I have it for my '06 Boxxer, but don't use the stem because it's not exactly what I want. I was thinking about making a stem to fit my Romic crown as well... I would definately very closely copy another stem design unless you want to use engineering software to determine stresses in your design.
    Glad to Be Alive
    so have i
    so you bash him and don't even know him or what he does.....does that make him bad???why did you hate him????
    SNOWRIDER
    Reputation: Deweydude's Avatar
    Good job! Custom stuff rocks
    Good luck on your stem, be sure to post up pics when you are done.
    I too am running a Boxxer and have been thinking about integrated stems.
    alot of you may remember my chain guide but here are the pics again
    "If you don't go [skibiking] this year, you'll be at least one year older when you do." ~ Warren Miller
    (Check out the 'IMPACT' video for some skibike footage)
    moaaar shimz
    Reputation: tacubaya's Avatar
    Lemme se If I get It, if you have some handlebar in that stem and the stem keeps it tight, how are you going to pusth the top part so it opens? You would have to slide the handlebar out if its flat, because I dont see another way.
    Also with a good crash the bottom part of the locking would just shatter.
    SNOWRIDER
    Quote Originally Posted by tacubaya
    I don't think I would trust that either........
    I want pics
    Aug 2005
    you dont know wat your talking about
    u obviously cant read designs very well
    and i made it out of tungsten so it wont break
    aircooled VW FTW
    Oh, So Interesting!
    Uhh, yeah...
    Pro Crastinator
    ....Also with a good crash the bottom part of the locking would just shatter.
    that part of the stem is made of ox-platnium steel, you couldn't bust it...
    Reputation: 006_007's Avatar
    It is responses like this that keep me coming to DH (forum)
    Me hates pinchflat
    Reputation: 545cu4ch's Avatar
    Aug 2005
    Youre wrong man. There is a large market for trailside-handelbar-swapping. What are you going to do if there is a steep section on the trail; put your butt behind the saddle Bahh, just put the highest rise handlebar youre carrying in your camelback.
    Quote Originally Posted by sriracha
    "jesus would huck it"
    Quote Originally Posted by FoShizzle
    i have found the 1.5" headtubes to be slightly larger in diameter than 1 1/8", plus or minus
    izumusx988
    Reputation: vpjackal989's Avatar
    why on earth would you want a quick relese on your stem? How often are you taking off your bars? Sounds like scab knows more than larry
    -Rob
    Northeast Sovereign racing - Morewood bikes-maxxis-hayes-e13
    Aug 2005
    Quote Originally Posted by vpjackal989
    wats a reason not to have one
    aircooled VW FTW
    Road/XC/Freeride
    Added complexity = more weight and less strength.
    Maybe in this case it works but we're still waiting for photos!
    I'm on the Twitter.
    fungus amongus
    Reputation: hilikus's Avatar
    ... its tmv55...frikin pirates raided my post...SNIF
    don't do anything else but ride bicycles..I'm a very complex individual
    Reputation: bob46802's Avatar
    Mar 2005
    do you not like what is currently available?
    Mar 2005
    a little chain roller/guide that I made
    here I have changed out the sloppy fitting cheapy bolts with some 180KPSI Aircraft ti bolts that actually fit the frame holes and shock bushings
    Outcast
    Reputation: Renegade's Avatar
    Larry, tell me your joking. If you knew anything about metallurgy or machining, you would know that tungsten, allthough hard, is also very brittle. Most often it's used as a minor alloying element in other metals, but in of itself, it would absolutely suck for a stem, or most any other component.
    Regarding 7075 AL; yes, it is stronger than 6061, but highly overated. 6061 is strong enough for most any application. I work with these materials every day, and have for 27 years now, so I do have a realistic background, as apposed to some of the folks in this thread.
