Results 1 to 7 of 7
    Reputation: trap121's Avatar
    Mar 2011
    Stripped 20mm thru axle...
    Does anyone have an idea on how to get a 20mm with stripped head out of the lowers of a fox 40?
    I went to remove it yesterday, loosened all the pinch bolts and proceeded to remove the axle and the Allen key completely spun through the head without budging the axle. It seems like this think is made of butter, I don't know what happened but I need to get it off ASAP. I'm calling Fox tomorrow to order a replacement which will be useless of I can't get the current one off. The threads are fine, it's just the Allen part is rounded out.
    Mountain Lion Bait
    Reputation: renderedtoast's Avatar
    Easy out?
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    That's gonna be a project that requires some finesse. I'd try using some thread penetrant to maybe help loosen whatever is causing it to bind. As for getting a wrench to fit, you might be able to reshape the rounded out hole to a bigger size allen by "carefully" hammering the wrench into the hole. A T handle will be easiest to keep straight and get a good hit with. You most likely will want to try a Standard wrench since the next size up in Metric will be a 6mm and that's gonna be pretty much impossible to force into the hole. There just isn't much material to get a grip on with that axle setup so you're kinda stuck using the existing hole. An easy out may do the trick as well but I've never tried it on one of these. Maybe somebody else will chime in with a simple idea...
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Drill two 1/8" holes in it and use a pin spanner.
    Pivotal figure
    Jan 2003
    ^Yes! Much better idea
    Mar 2011
    Great idea...you think that would compromise the strength of the axle? I could probably reuse it doing that, and avoid the $70 for a new one....for a little while anyway
    May 2005
    It'll be fine. It's not like you have to drill them deep, and there's a ton of material on the end there.
  1. Heckler pivot axle nut stripped
    By drowe303 in forum Santa Cruz
    Last Post: 06-19-2013, 09:33 AM
  2. Stripped axle bolt on Tune hub
    By LUW in forum Cannondale
    Last Post: 02-19-2013, 10:24 PM
  3. Replies: 19
    Last Post: 04-15-2012, 05:34 PM
  4. Techies: Stripped 20mm thru-axle??
    By $ally Hu$tle in forum Shocks and Suspension
    Last Post: 09-02-2011, 10:57 AM
  5. fox 40 axle head stripped
    By seanzombie1336 in forum Downhill - Freeride
    Last Post: 04-12-2011, 06:24 PM
