Results 1 to 6 of 6
    Reputation: Coldfire's Avatar
    New question here. Sram X.9 rear der. w/ a Deore lever?
    Hi,
    I have a short question: my XT is completely destroyred so I need a new rear der. I have a 9 speed Deore lever. Will it be compatible with a Sram X.9?
    Coldfire
    I'm such a fox
    Reputation: endoMaster's Avatar
    Quote Originally Posted by Coldfire
    Hi,
    Coldfire
    No, you need to use a Sram shifter with 1:1 ratio.
    Sram Attack Trigger?
    For example a Sram Attack Trigger Shifter? Is it any good?
    Coldfire
    Uhhhhh...
    Reputation: TheSherpa's Avatar
    Coldfire
    No, those would work with a Shimano der. Get X-7 or X-9 triggers to run with SRAM rear der.
    -TS
    Fayetteville, AR and N.W.A RePrEsEnT
    I'm such a fox
    Coldfire
    Sram Attack and Rocket shifters will work with Shimano derailleurs, X series trigger and gripshift shifters will only work with Sram derailleurs.
    Ok
    Thanks for the info. Those are quite expensive hard to find here...
    Coldfire
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. STX rear der and XT deore shifters?
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2004, 02:36 PM
  3. Can I get away with this SRAM x.9 rear D?
    By danK in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 03:01 PM
  4. Sram rear der with XTR triggers? I'm sick and tired......
    By Spongebob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2004, 03:35 PM
  5. Beginner, want a FS bike, which one?
    By Rich4757 in forum Bike and Frame discussion
    Last Post: 05-31-2004, 07:40 PM
