Results 1 to 12 of 12
    Reputation: jmallory's Avatar
    Specific requirements for a new frame- HELP!
    I am currently riding a Sette Venom 7" ride right now and I am looking to upgrade. I was deadset on a Transition Blindside but I saw it requires a Shimano Direct Mount front derailleur. I have a SRAM top/bottom pull X7 now and want to swap it to the next frame. Need something that will accept that and has 135 X 10mm rear, 73mm bottom bracket and full length seat tube for riding up hill. 7 to 8" rear travel preferred. I love the idea of the Blindside, but the front derailleur issue is holding me back. Is there another out there or do I just bite the bullet and change out my drivetain?
    Thanks to you all!
    Reputation: mattyboi's Avatar
    Oct 2010
    from wat i can tell on there site it doesnt actually need that crank and that wouldnt really make sense to only be able to fit that certain crank im sure it can fit most cranks with iscg and the proper bb size.... and my race team has a sponsor from transition and the one kid had one with a different crank on it dont remember wat it was tho
    keep the rubber side down!!
    I appreciate the reply, but I'm not too concerned about the crank since its standard 73mm bottom bracket. My issue is with the front derailleur being Direct Mount and if there are any other frames that I'm not thinking of. I currently have a SRAM X7 at the moment.
    Dec 2004
    What year blindside? if the reason you don't want direct mount is because of the cost id say pony up. Do you know what your looking for in head angle and BB height?
    bike rider
    Reputation: Lelandjt's Avatar
    From that description, how about a SC Bullit?
    Keep the Country country.
    not being able to transfer your fd sounds like the worst reason to not get a great frame..IMO
    you can get a direct mount fd for less than $40
    newless cluebie
    Quote Originally Posted by tyler243 View Post
    This.
    A FD, even an X0, will cost you well under $100.
    You're thinking of dropping close to $2K on a frameset, yet you won't pony up the incidental costs? Hell, a full recabling of your derailleur cables will cost as much as a FD.
    My Trifecta: Rocky Mountain Flatline Pro, Rocky Mountain Slayer SXC70, eBay Carbon Hardtail
    Its not just a front derailleur, I'd also have to buy a shifter since I am currently running SRAM. If I'm gonna do that, I may as well change the rear to Shimano as well. Not the most expensive thing to do, but the frame is at the top of my budget. Another $200-$300 is a tough sell to the wife. I found out that it will accept my current drivetrain, so its no worries anymore. Thanks for the input everyone!
    newless cluebie
    Erm, unless you're running XX, SRAM and Shimano front derailleurs' cable pull ratio are the same. Aka you can use your X7/X9 front shifter with a Shimano front derailleur just fine.
    In fact that's what I run: X9 shifters, X9 rear derailleur, XT front derailleur - on my carbon HT.
    I thought SRAM was 1:1 and Shimano 2:1. If I'm wrong, great!
    Reputation: monstertiki's Avatar
    Quote Originally Posted by jmallory View Post
    You can use a sram front shifter with a shimano FRONT derailleur. Im running an x9 on my delirium with a shimano xt e type deraileur. Get the frame you want and don't let that deraileur boss you around.
    Thats only the rd. Fd is cross compatable
    Oh and sram now has some direct mount fds if i recall correctly
  1. Basic Thru Axle Question (Frame Requirements)
    By SpaceBrain in forum Wheels and Tires
    Last Post: 05-16-2007, 09:11 PM
  2. Replies: 18
    Last Post: 08-18-2006, 07:08 PM
  3. Replies: 0
    Last Post: 08-17-2006, 05:10 AM
  4. eno hub vs SS Specific frame
    By gsteinb in forum Singlespeed
    Last Post: 07-28-2005, 09:11 AM
  5. very specific frame ?
    By cmd in forum Downhill - Freeride
    Last Post: 06-11-2005, 12:12 PM
