Results 1 to 32 of 32
    Soft Ride Shuttle Pad
    Anyone get one yet? How's it compare to DaKine?
    For The Win
    Reputation: StinkyFTW's Avatar
    I'd guess they work equally well. As long as it stays in place there isn't much else to worry about.
    Slow is cool too, right?
    Reputation: fixbikeguy's Avatar
    I'm interested to know as well. Does it have better padding? Do the straps that hold it onto the tailgate hold up better than the DaKine ones?
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    I bet the Dakine logo looks way better
    Ground Steeze. @iggy_strbac
    If you think you can
    Reputation: 62kona's Avatar
    The Dakine logo is so sweet! It will probably clean your bike off too!
    The thing I like is it straps the bikes so they don't bounce around on rough shuttle roads
    EastBaySteez
    Reputation: Freerydejunky's Avatar
    Neither of which covers the bumper.
    10 dollar heavy duty packing blanket from HomeDepo or Lowes... wins every time.
    Gamut
    Team Evil
    Formerly: motormonkeyr6
    I'm currently using the moving blanket. Not nearly enough protection from dinging your frame on rough shuttle roads. I add pipe insulation foam underneath the blanket to protect the frame. With the foam, nothing touches the bumper.
    pfb
    pfb is offline
    I've been checking these out as well...
    Looks like the Softride version has straps to hold the bike down on the pad. Does the Dakine have them as well?
    Mine is coming Wednesday. Ill post a review with pictures.
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Quote Originally Posted by pfb
    No the Dakine doesnt. I hope the soft ride is better, because the Dakine is a POS! Ive had 2 of them and on each when you tighten the strap down it everntually tears the material/seams apart and the more you pull the more it tears.
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
    Glad to Be Alive
    Quote Originally Posted by motormonkeyr6
    i am with you on this
    I'm using the moving blanket method right now with foam pipe insulation underneath. Doesn't keep the bikes from bouncing on rough shuttle roads. I want to see if the straps help with better padding. I dont' want dents on my downtube.
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    Quote Originally Posted by Guy.Ford
    Neither one of mine have torn from th straps, they do develop cutz along th top edge due to 45 lb bikez laying on it bouncin down th dirt roadz. Maybe yer strappin'er down too tight....?
    "Why are you willing to take so much & leave others in need...just because you can?"
    #THELEGEND
    Quote Originally Posted by man w/ one hand
    I guess its possible, if the straps are only there to keep the pad from blowing off when you drive then yeah probably too tight, but if they are meant to keep the pad in place and stop if from rolling over than Id say Im not pulling them too tightly. Meh not a big deal to me, just sharing my experiences and experiences Ive seen with others using the same pad, believe me Im not alone.
    #THELEGEND
    2016 RSD Mayor
    EastBaySteez
    Quote Originally Posted by 92SE-R
    Run a tie down strap over all the bikes if you are on a rough shuttle road...
    Problem solved.
    Gamut
    Team Evil
    It never really works. Trust me, I've tried. Unless u have 5 frames that are identical, the top tubes are never the same height and one or two bikes will always be flopping around.
    Problem solved.
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    Wrap the tie down around each of the top tubes and tension it, problem solved.
    Have you ever tried this before? It does not work. It only snugs down the outer two bikes and pulls the bikes into each other.
    Quote Originally Posted by Gemini2k05
    #THELEGEND
    I can concur the 2 aforementioned ideas of using tie straps over the top never works
    #THELEGEND
    2016 RSD Mayor
    Reputation: squiby's Avatar
    Try using the tie down strap but loop it once around each seat post just above the seat post clamp. If you start with the all bikes leaning a little away from the ratchett and make sure the strap is tight between each bike, as you tighten the bikes will come up straight and keep the separation distance. This gives a bit of tension on both sides and stops the bikes coming together. Works for me. If you've got crap on your downtube or going on a long trip road vibration always rubs the downtube and messes with the finish, whatever your using, even if it is tied down. I can't see the little loops on this one making a difference. Pays to throw a shin protector/rag/foam/glove/whatever between the bike and tail gate pad/blanket if you bike is purdy. That pad only has straps for 6 bikes. A truck can fit 7.
    Quote Originally Posted by squiby
    With the price of these bikes, the most that I would jam into the back of my truck was 5 on the tailgate. I didn't like the way the bikes would move around and toptubes got dinged by brake levers and downtubes got dented so I bought a Northshore Rack that holds 6. Way better than the tailgate pad.
    Quote Originally Posted by fixbikeguy
    You're right, the Northshore Rack is a solid option! Comes down to $$$, convenience, preference and whether you need the truck for other stuff. A blanket and strap thrown in the back is cheap 'n easy and I have not had any issues with bikes loaded in the fashion I described. A NS rack on a dedicated rig would be sweet though. It would protect your truck better too.
    Professional Troll
    Apr 2005
    Yes, I have. It's not perfect, but it definitely helps.
    Bingo. That's the best solution that I have embraced. It's expensive, but it looks like it'll last a lifetime.
    Saw one of those NS racks up in Snow Shoe last summer cool lookin, but i think th padz are the easiest, cheapest way of haulin a bike, purchased or adapted, (i.e. furniture pad or heavy blanket).
    Reputation: HighTitan's Avatar
    Ive been useing my Dakine tailgate pad for years now, prob have over 12,000 miles of hualing bikes on it (jersey to cali, cali to Jersey, to south carolina and to many races.) the stitching at the straps did rip a little but I realized it doesnt have to be super tight. its not going anywhere with a couple bikes on it.
    I like to ride bikes fast.
    Just roll it......
    Reputation: ebxtreme's Avatar
    Only mid bummer about the NS rack is you can get a bit of wear on the crown or headtube of your bike. Still a VERY minor issue compared to tailgates or other systems.
    FYI, a couple buddies just started a small rack company called shuttlenuts. Their site still needs some love, but here it is. If you've got a shortbed, these work great because it helps give extra room in the truck for people, gear, dogs, etc.
    pfb
    pfb is offline
    Thanks for the review. Just ordered one to upgrade my moving blanket!
    Reputation: spoothead's Avatar
    May 2010
    I've had my softride pad for about 10 months. I've never taken it off and its usually parked outside in the sun. Both the straps on top and the ones that hold it to the tailgate have dry rotted. The straps on top were gone in about 6 months.
    But other than that I've loved it. Yeah it'll wear some paint off your downtube, and off the lowers of your fork. But put stickers on places that rub or get some 3M automotive tape.
    pfb
    pfb is offline
    Two posts up, I mentioned buying the Softride pad... That was a year ago.
    What I never posted was that I test fitted it once and promptly returned it. It was bulky, fiddly straps, and offered little advantage over the heavy weight moving blanket I now use.
    Being able to keep the moving blanket always in the back of the truck means I don't have to plan in advance when I want to haul bikes, and don't have to find a place to store the large, un-folding, inflexible softride pad when not using it.
    If I had a truck that was constantly being used for shuttle duty, maybe the softride would be worth it, but it's not for me.
    dirt visionary
    Reputation: clockwork's Avatar
    The softride pad is lacking the quality of the dakine first hand experience..Dakine lasts and lasts the softride straps are crap in comparison and sun ate thru them in short order..Also if you can't figure a way to use straps ot bungees to keep bikes in place you need more practice..Here in AZ almost all our shuttle roads are rough arse roads with long shuttles.. after 7 years of shuttling dakine still holding up doubt the softride will last another 4 months.Also when comparing the two the dakines padding is superior
    Life should NOT be a journey to the grave with the intention of
    arriving safely in an attractive and well preserved body.
