Results 1 to 12 of 12
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    soft grips vs. hard grips?
    after a few runs down the mountain my hands hurt. a guy i was riding with said it's because i have soft grips and i'm squeezing harder to get a good grip on the bars. he suggested i get harder grips and it would reduce how hard i grip the bars...
    ?? any suggestions, or other input?
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    I find that the overall thickness has more impact on my hands than the rubber compound. Too thin and I get blisters (hands kinda float around), too thick and I get fatigue (can't grip properly or reach the brakes without effort).
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Grinder
    Reputation: nogod's Avatar
    wear padded gloves
    Quote Originally Posted by a stoned guy with a beer in his hand eyeballing your sisters bike
    "i fit my bike to fit me;not for looks...nice did you buy that bike from jc whitney?" Stoner Island 1984
    Quote Originally Posted by kenbentit
    I found the same thing with thicker grips. My hands would get fatigued faster. I haven't had any issues with the thinner grips that I run, but maybe they just aren't that thin. I've had really good luck with the ODI Ruffian grips, FWIW.
    I could gap that.
    It's typically the thickness of the rubber of the grip and not the compound itself. I was having the same problem. Was using the Specialized Thin lock on grip and I was getting major blisters and my knuckles would be sore after a while. Switched to the ODI Rogue and haven't had any problems since.
    Demo 8
    P1
    http://www.chainsmokeracing.net/
    Sponsors: Twenty6, ODI, Elka, Crank Bros, Sixsixone, Azonic, Specialized
    Definitely try them out before you buy if possible. Although not a major investment, $20-$30 for grips a couple of times can add up. It really comes down to personal preference and your anatomy/size and shape of your hands. I found that for me the Rogues were a little too thick compared with the Ruffians. I have ridden on both. I ended up putting the Rogues on my wife's bike and she seems content with them. Not sure she would be able to tell the difference at this point.
    Feb 2006
    thank you all for the advice, i'll have to do some shopping
    '11 Jedi
    Most hand pain goes away with more experience. As you get more comfortable on the bike, you won't squeeze the grips, and you will start anticipating the jolts and picking smoother lines.
    That said, there are two grips that work very well: ODI lock-on Ruffians for smaller hands, and Rogues for larger hands. I run unpadded XL motocross gloves (absolutely cannot stand padded gloves) and Rogue grips.
    Oct 2011
    so what the guy said before
    im the stage of learning to jump and trail ride stuff
    i think its got more to do with how tense you're body is
    i found the more relaxed you are the less have soft girp or firm grips is going to matter
    i have found in sports that technique is about over half of it have good technique you dont have to worry
    Reputation: freeriderB's Avatar
    put one grip on the left...and a different one on the right.
    take a few runs to see which feels better.
    my experience led to thinner grips (I've tried EVERY ODI)
    I think my last choice were the Chargers...I think Lizard Skins makes them. Just like ODI.
    As for gloves. I run them TIGHT. Baggie and loose fitting gloves cause friction, and the constant sliding back and forth with sweaty hands will cause blisters.
    Try adjusting your bar too. A little tweak makes a big difference on how you grip, and the overall tension placed on your fingers, hands, wrists, forearms...etc...
    ESI grips. They are not the longest lasting, but they are comfortable as hell, and great against numbness.
    Reputation: Calhoun's Avatar
    Nov 2008
    Quote Originally Posted by morandi View Post
    second that. throw some of these on the bar ends and the grips won't get shredded as fast.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
