Results 1 to 5 of 5
    Sep 2012
    Shimano Zee Brake Hose
    Hi guys i've just ordered a Shimano Zee Caliper and i was wondering if anyone could tell me which hose to get? The Shimano Tech Docs indicate I need the SMBH90 but it looks like that one has a banjo connection one end and a sirect connection the other, and as far as i know the Zee caliper has a direct connection (the lever i have is also direct connection), anyone got any ideas?
    thanks
    The Zee caliper uses a banjo.
    The BH90 is what you need, however others will work.
    Sep 2014
    Quote Originally Posted by FreeRidin' View Post
    I also bought Zee calipers separately. Can you tell me how to tell which others will work? I'd like to get lighter hose if possible. My SB-95 is quite a hog.
    Reputation: Wombat's Avatar
    Check out this: http://www.shimano.com.au/publish/co...stallation.pdf
    Any hose with a banjo fitting for the caliper and in-line at the lever will work.
    Tim
    Sep 2014
    Re: Shimano Zee Brake Hose
    Quote Originally Posted by Wombat View Post
    Tim
    I thought that the inside diameter and outside diameter of the house differed by application
