Results 1 to 7 of 7
    Flying High Again
    Reputation: Ripzalot's Avatar
    Rockgardn CYA Shorts.....or other?
    Anyone using the rockgardn cya shorts? I'm wondering how comfortable and/or hot these are under your normal shorts. Or another padded undershort option? 661? Fox? etc. Any opinions welcomed.
    Also, do they fit well under your regular sized shorts or do you need to go up a size for them to fit?
    THANKS
    go with rockgardn!!!!
    Quote Originally Posted by Ripzalot
    THANKS
    may have to go up a size in shorts but rockgardn is the only way to go...the only time you fell them is when you hit the ground!!!
    i should be working
    Reputation: rpl3000's Avatar
    i got a pair
    i have a pair and the sizing is on, i didnt need to go a size up. they fit very well under anything, even pants. i got them and wore them last fall and this winter so i cant say how they will be in the summer heat but i'll find out. hope this helps -ron
    Reputation: jr711's Avatar
    they're pretty comfortable to to wear. its hot in southern cali and they seem fine to ride around in. its made out of a lycra net kind of material. so its not like tight spandex with padding. i have no problems wearing them under my normal shorts.
    i haven't landed on my tailbone yet but it has lots of padding for that area. i've landed on the sides and it still hurts! but i bet it would have hurt a lot more with out them. for some reason i feel like i want some padding on the front of the thighs. but i don't think its common to hit that area. i use 'em for snowboarding and it works well there too.
    i've never worn any other kind of protective shorts so i can't really compare. but i'm sure the cya shorts are more comfortable to wear than chamy type shorts with padding
    i really like rockgardn, but i saw these on pricepoint.com. they look exactly the same as the cya shorts.
    http://www.pricepoint.com/detail/130...der-Shorts.htm
    Reputation: Darknut's Avatar
    ... and if we just ... CYA shorts
    I have the CYA shorts and they fit good .
    Haven't crashed with them on yet
    A 24",3.0 lovin Hack!
    http:www.somefeargear.com
    I have the Skelton paded shorts
    and man do they sweat like a pig. They cut off the cirulation around my thigh. They stink like a dog. Uncomfortable as hell. But they make you mad and pissed off so you go big....
    Bill Dog
    Reputation: Slack's Avatar
    THANKS
    I love my CYA's. They have great air flow in the front and nice padding on the sides/back. I've had a few crashes (just low speed) with them and they did help.
    I only wear them under my baggy DH shorts, so there's no fit issues. But you might wanna go up one size depending on your shorts.
  1. Lycra shorts sale ($35) at Voler
    By logbiter in forum Apparel and Protection
    Last Post: 04-14-2004, 07:30 PM
  2. Good shorts, cheap
    By Lucky in forum Where are the Best Deals?
    Last Post: 04-07-2004, 11:14 AM
  3. women's bike shorts
    By JustDoIt in forum Women's Lounge
    Last Post: 04-02-2004, 11:59 AM
  4. Baggy shorts or stick with Lycra
    By Nim in forum Apparel and Protection
    Last Post: 03-13-2004, 07:49 PM
