Results 1 to 2 of 2
    Rear shock bushing play.
    So I recently built a bike up, and from the get-go the rear shock bushings have had an eency bit of play. The bushings I used were brand new, so I don't think getting new bushings would help. So my question is there any remedy besides new bushings? and would this be considered a serious issue? as in, if I don't do anything about it, will I damage my frame?
    Glad to Be Alive
    it's a serious issue....that extra bit of play gives jolts back and forth that can ovalize shock to frame mounts
    first off tighten all pivot bolts
    then check for....
    right size bushings
    bolt size compared to bushings
    side to side width (including spacer width)
    switch same size shocks to see if it is an inside shock problem
    make sure frame isn't ovalized all ready
    check headset
    check front and rear hub
    check bottom bracket, cranks and pedals
  1. 2010 enduro shock eye bushing play
    By brad72 in forum Specialized
    Last Post: 08-10-2011, 11:13 PM
  2. Rear shock bushing Q
    By C.M.S in forum Shocks and Suspension
    Last Post: 08-05-2011, 09:05 PM
  3. Rize 130 rear bushing play?
    By Elzippo in forum Cannondale
    Last Post: 02-22-2010, 03:07 PM
  4. Rear Shock Bushing
    By Biscuit Pants in forum Giant
    Last Post: 09-05-2006, 09:10 PM
  5. Play in bottom shock bushing
    By Michal in forum Giant
    Last Post: 05-23-2004, 10:03 AM
