    Oct 2012
    rear coil sizing problem
    i recently purchased a heavier rear coil/spring for my x-fusion glyde shock since my previous one bottoms out crazy easy. the lighter coil is 350x56 and the one i bought was 550x2.25. from what i read scouring threads for hours, 550x2.25 was what i needed for a new coil. when i received the new one, it was way bulkier and just all around bigger. the length of the new coil wasnt that big of a deal but the diameter was the problem. the old coil's diameter was 33mm and the new heavier on is 38.5. i just want a 550 pound coil that fits. im really new at this if you havent noticed. should i just buy a new coil? if so, how can i stop this from happening again?
    Thanks,
    Scott
    Quiet Professional
    Reputation: chef7734's Avatar
    Re: rear coil sizing problem
    Well 56mm is 2.2 inches. You sure it is not a 200 x 57 shock?
    Sent from my Transformer TF101 using Xparent BlueTapatalk 2
    Reputation: cerebroside's Avatar
    Quote Originally Posted by Mr._S View Post
    ...the length of the new coil wasnt that big of a deal but the diameter was the problem. the old coil's diameter was 33mm and the new heavier on is 38.5. i just want a 550 pound coil that fits. im really new at this if you havent noticed. should i just buy a new coil? if so, how can i stop this from happening again?
    Different brands use a different coil interior diameter. I can't tell you if the diameter difference you have measured is going to be a problem or not, but before you buy a new one just google the diameter of the brand you are buying to check.
    Oct 2012
    alright, thank you!
  1. problem w/ works components headset sizing....
    By bing! in forum All Mountain
    Last Post: 11-09-2012, 08:38 AM
  2. Sektor Coil problem
    By haakan in forum All Mountain
    Last Post: 05-02-2012, 08:56 AM
  3. Rocky Mountain RM6 - Coil Spring Sizing
    By jtr101 in forum Shocks and Suspension
    Last Post: 04-21-2012, 04:28 PM
  4. 2011 Trance X4 sizing problem
    By bimmerjack in forum Giant
    Last Post: 09-26-2011, 06:20 PM
  5. Marzocchi Roco problem. Sizing and Clunking
    By coolatt in forum Shocks and Suspension
    Last Post: 06-24-2011, 04:53 PM
