Platform Pedal Shootout!
2018 Update for best pedal:
As a single speed rider, I prefer the simplicity and get on and ride how you come approach. The general rule when it comes to pedals is, if you cant ride with flip flops or jack purcells, your bike is a failure.
Figured I could pop this in any category like singlespeed or 29er but downhill freeride riders are the most renown for rocking platform pedals in even the most intense, dangerous gravity induced situations successfully.
While weight is often shaved and marketed in connection points on the bike (saddle, handlebar, pedals), these are the most important to me to feel solid to the rider. Saving weight elsewhere is a better move 'cause the solid feel equals confidence.
I reviewed four foundational pedals. While all superb pedals, I found the winner of these four - the Sunline V-One platform pedal.
:eekster:
Atomlab Trailking: an innovative design that has been copied by everyone, the 17mm thin crowd got its inspiration from this pedal. Sweet looks, my favorite in the looks department, CNC machined minimal with a fantastic shape and really looks tits mounted to a single speed and is thinnest body of the lot. Due to DU bushings (which are the least desirable), it develops play quite easily, so have a stash of DU bushings for replacements and the problem is solved. Atomlab is good about providing these replacements and they're fast, simple to replace with an allen key. The performance is least of the lot due to pin placement, flat body, and DU bushings - my foot has slipped jumping off street curbs! Studs did rip a number of holes and lines into my shins causing permanent scarring and for the lackluster amount of grip they provide, wasn't worth it. The newer Pimp and Pimplite mag pedals have resolved the DU bushing issue with sealed bearings while staying with a similar shape. 540g pair, $100
Easton Flatboy: a design that is over ten years old! Classic, beefy, concave and grippy. Comes in only ano black, matches your Easton cockpit. A bit boring as the design hasn't changed for decade - meaning the pedal works well! 572g pair, $75
Syncros Mental Stainless Steel: the rawest of the bunch, made of stainless steel versus aluminum like the others. Also like the fact that you dont see rebrands of this pedal 'cause they're so ugly, no one is going to copy them. Random non-bike people will ask you about the pedals. A whopping weight penalty, almost double that of the other pedals, but it's easily justified as these just are the last to break from any ravishing hit or scrape. I treat them badly and they look identical to new. I really like the way these spin and the heaviness works by providing a solid connection to the bike. Lifetime warranty on the bodies to prove it! 800g pair, $80
Sunline V-One: Solved the problems of the Atomlab Trailkings by using loaded sealed bearings, concave body, and added the machined pyramids from the Brooklyn Machine Works Veggie Burgers and notorious Shin Burger pedals. When the stud screws are installed on top of the pyramids, your foot is not slipping, at all. Best grip of the lot. Anodized gunmetal blue titanium to match the Sunline V-One cockpit. Also very close to the Hope Tech X2 Pro Mini carbon fiber edition anodization. 580g pair, $120
MTBR reviews 5 stars for the V-One's: https://content.mtbr.com/cat/drivetrain/pedal/sunline/v-one/PRD_416992_135crx.aspx
This shootout comparison test is missing some serious talent, help me fill that in, MTBR members!
Shimano DX, Straitline, Burgtec Penthouse, Odyssey Trailmix, DMR V12, NYC Freeride Glory Hole...
Brooklyn Machine Works (CNC) Veggie Burger: Brooklyn Machine Works Veggie Burgers Pedal user reviews : 5 out of 5 - 26 reviews - mtbr.com
Canfield Brothers Crampon: Canfield Crampons 6 month review = they are solid- Mtbr.com
Point One Racing Podium: Point One Racing Podium Pedals short review- Mtbr.com
Answer Rove FR, Nukeproof Proton, Deity Decoy and the lot of re-branded HT Components (Taiwan) pedals. Hey, if you can get the HT originals for fifty bones with titanium spindles at under 300g, who's to say?...
:madmax:
- high range: Gamut Podium for class, weight, height, uniqueness, aesthetics, performance, size, desirability with roots in the SF Bay Area Point One Racing small CNC operation, 3rd generation design lineage
- low range: Lixada Y2259B for value, comparable to any VP/HT/Wellgo ultra-thin-light-wide pedal, and an unbeatable value $24-29 shipped to your door from multiple online sources
:eekster:
:madmax:
