Page 62 of 81 FirstFirst ... 12 52 58 59 60 61 62 63 64 65 66 72 ... LastLast
Results 1,526 to 1,550 of 2006
  1. #1526
    If these came in another color (purple) I'd love to give these a shot. At $69 though, I'd probably just grab the Deity Decoys still.
    http://anvlcomponents.com/2013/Product_Pedal-TiltComposite.cfm?Token={ts_2014-08-19_16:57:23}-c98b3c2a859721c6-62BED800-F6FF-E2FE-E7D9A90D447C219B#thumb
  2. #1527
    Aug 2013
    Quote Originally Posted by jojotherider View Post
    Quote Originally Posted by ANVL
    3 cartridge bearings + 1 DU bushing
    I like the way that sounds when saying it in my head!
    Wonder if I can get the LBS to order these since they are selling Canfields.
    I drive more when the streets need repairs!
  3. #1528
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Platform Pedal Shootout, the best flat is...
    Quote Originally Posted by kragu View Post
    Curious, where do you find that each excels over the other?
    The Predators are bigger and grippier, by a good margin. But being bigger, they're slightly more prone to rock strikes, and those cost me traction pins. I use them around Montana, although I don't have them on at the moment, since I need to get some more pins. The Canfields are smaller, thinner, and have thicker/more robust pins. They're my desert pedals.
    "Back off, man. I'm a scientist." - Dr. Peter Venkman
    Riding in Helena? Everything you need to know, right here.
  4. #1529
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Quote Originally Posted by pdxmark View Post
    I have Odyssey pedals on my 24" DJ and they have lasted for two years now, even with some serious bails. Thinking maybe I should just get some for the MTB?
    Which model Odyssey are these?
    26"
  5. #1530
    Aug 2013
    Quote Originally Posted by J. Random Psycho View Post
    Sealed bearing trail mix
  6. #1531
    Apr 2014
  7. #1532
    meow, meow.
    I'm 99% sure it's not a replica, and both brands are made at the same factory..
    26"
  8. #1533
    NWS
    NWS is offline
    Jun 2010
    Yeah, HT seems to be happy to make pedals for other people to sell under other names. If you look through all of the pedals at HT's own web site, you'll probably recognize a couple that you've seen before, but with other brands on them.
  9. #1534
    Reputation: zuuds's Avatar
    Another set of XPEDO SPRYs or go big?
    I have a pair of XPEDO SPRY's, I had them on a dirt jumper for a while, They held up great in that application, since they never saw rocks.
    For the last several months I put them on a Nomad for trail riding. They're holding up pretty well. I've torn a pin out, and while there are still threads in the hole, replacement pins never stay put in that hole, as the outer threads are gone. However they're still spinning great and haven't developed any play.
    I'm building up a Banshee Spitfire and looking for pedals for that bike.
    There are lots of enticing new options such as the RaceFace Atlas, the new and improved Point One Podium, and Spank Oozy, to name a few. After reading over several pages of this thread, from the comments I'm gathering that the Canfield Crampon Ultimates are one of the sturdiest pedals in the 11-12mm thick category.
    The Spitfire has a super low bottom bracket, so its pedals will definitely be getting some rock time. While SPRY's have held up for me pretty good so far, I'm not sure that would be the case on the Spitty.
    I'm not that concerned with weight, although the lightness of the SPRYs is a nice bonus. I'm spoiled by the 11mm thickness of the SPRYs and I'm never going back to thicker pedals.
    I'm debating whether the spendy $150+ pedals such as the Podium and Crampon are worth it in this situation. Certainly they'll be more durable than the magnesium SPRYs, but from a dollars and cents standpoint, SPRYs can be had for as little as $50 on Ebay, so I could get three pair for the price of one pair of Crampons...
  10. #1535
    Reputation: cerebroside's Avatar
    Durable, cheap, thin/light. Pick two (or compromise a bit).
    You could save a lot by going slightly thicker. I'm running Nukeproof Electrons, which are 17mm thick (and $43 CAD IIRC). I haven't tried anything thinner, do you think the difference would be noticeable?
  11. #1536
    Quote Originally Posted by cerebroside View Post
    Enormous difference. Prior to the SPRYs I had Wellgo MG-42s, which have similar dimensions except they are 17mm thick. The difference in pedal feel between the two is very noticeable.
  12. #1537
    based on the design of those pedals, I would say the difference is less in the thickness of the pedal and more to do with the profile design. The MGs are more of your old school/bmx platform. Its a flatter surface for you to stand on. The Sprys look like there are more contours for your foot to rest in. So while they may have similar WxL dimensions, I don't think the thickness is what makes them different. I can't imagine a 17mm Spry would feel much different from the 11mm spry (all else being equal).
    I personally think if you're going with the expensive option, you should go with the Podiums. Looks like its similar in shape to the Sprys.
    Full disclosure, I've never ridden any of these pedals. I'm basing my opinion on what I've seen online.
  13. #1538
    Reputation: metrotuned's Avatar
    jojotherider, I've owned all the pedals you mentioned. You're right on point, pun intended, based off the judgements you've made from this thread and what you've seen online. Let's see what Interbike 2014 has to offer from Las Vegas. And I'm curious to try the Canfield Brothers first generation pedals and still curious to try the Syntace pedals with the three different platform sizes and ultra-uber high price tag (those pesky German design valuations).
    Lead actor Will of the Sun, Author Platform Pedal Shootout 820K views
  14. #1539
    NWS
    NWS is offline
    Jun 2010
    If rock strikes are a concern, consider Hope's F20 pedals. The profile isn't particularly thin, but the pin design is brilliant. I bought a set for my DH bike after shearing a couple pins from the HT pedals that I was using before.
    F20 Flat Pedal | Hope Tech | Made in Barnoldswick, England
    Hope's pins thread in from the top, using a hex wrench that you insert from the bottom. So unlike bolt-style pins that thread in from the bottom, if a broken pin ends up with a burr on the threads, you won't have to drag the burr through the pedal (damaging the threads) in order to remove the pin.
    And unlike grub-screw pins that thread in from the top, you can still use a hex key to remove the pins after the top gets sheared off. (This is what screwed up my HTs - they had grub screw pins in the center of the platform, and once those went, the pedal didn't grip half as well and there was nothing I could do to fix it.)
    And Hope's pins have a flared base that sits snug in a little pocket in the pedal, which should make them more resistant to breakage in the first place.
    Ten pins per side, nicely distributed.
    $150ish, but I'm hoping that they'll last for a long time. And not especially thin, but I'm OK with that. I didn't feel much difference between the HT AE-01s I was using (thin, but grub screws) and more conventional pedals.
  15. #1540
    My arm hurts a little
    Reputation: #1ORBUST's Avatar
    Tried every single flat in the op. They are all meh!
    Best flat I've tried is speedplay drilliums.
    They are a little on the fat side. They arnt low pro but they are 10/10.
    My group has a combine 18 or so years and never 1 problem. I'm in year 6 or so and they are still $$$$$!
    They use a combo of needle and cart bearings! You'd have to be 1000lb plus to break them.
    Hardtail downhill
    https://youtu.be/sXhWDoz7_CM
    Quote Originally Posted by SHIVER ME TIMBERS
    tresspassing, thievery and poaching is all part of a DH'ers life
  16. #1541
    Speedplay Brass Knuckles
    Brass Knuckles, Speedplay's 13.5mm thick flat pedals, spin on two cartridge bearings and a needle bearing, and have ten star shaped traction pins on each side. $175 cro-mo 400g weight. Excessive all around. They might want to stick with their spd pedal line...
    Picture of Brass Knuckles below:
    Platform Pedal Shootout, the best flat is...-speedplay-pave-pedals-brass-knuckles20130916_0012.jpg
  17. #1542
    Good job! Improvement on the VP Harrier
    Platform Pedal Shootout, the best flat is...-vp-harrier-altitude-2.jpgVP Harrier Altitude, solidly sculpted with exposed CNC machining details and that gold titanium spindle. Hot!!!
  18. #1543
    Apr 2014
    Re: Platform Pedal Shootout, the best flat is...
    Quote Originally Posted by illnacord View Post
ID:	926431VP Harrier Altitude, solidly sculpted with exposed CNC machining details and that gold titanium spindle. Hot!!!
    Where did you get the ones with the ti spindle?
  19. #1544
    I have Wellgo C 135's and B 132's shown below. the 135s are about 300g, and the B132's are about 350g. Both should cost around 50 bucks, but i haven't priced them lately.
    the 135's are on the small side for a platform, but are fine for me. I was worried about durability but I have used them for a couple of seasons straight, and they have hit many rocks with no issues.
    The 132's are bigger, and seem more solid, but are still very light. I haven't used them as much, but still seem perfectly adequate.
    Some of these fancy 100-200 dollar pedals here loook kind of cool, but I can't get excited about pedals too much. I put my foot on them and they need to have grip and spin around and that's it.
    Even these super high priced and Ti fancy pedals wouldn't save me any weight.
    Attached Thumbnails Attached Thumbnails Platform Pedal Shootout, the best flat is...-wellgo_b132.jpg
  20. #1545
    Reputation: Bike Doc's Avatar
    Oct 2007
    The Honey Badger Pedals
    I ride the Honey Badger Pedals because Honey Badger don't give a $hit where I ride or what I ride over or through!Platform Pedal Shootout, the best flat is...-dsc07339-low-resolution.jpgPlatform Pedal Shootout, the best flat is...-dsc07358-low-resolution.jpgClick image for larger version.
Name:	DSC07339 Low Resolution.jpg
ID:	928936Click image for larger version.
Name:	DSC07358 Low Resolution.jpg
    Here's a few of the stats on the HoneyBadgers: 4.20 inches x 4.20 inches; 3.2mm thin on front and back edges; 3mm on outboard end, 2mm all around center mud clearance hole; angular contact, full compliment bearings; 8 reverse taper, length and diameter optimized traction pins; 16 fangs; twice the amount of mud clearance as FlyPapers; under 500 grams; better sealed bearings than the FlyPapers; 14.2% smaller diameter backside bearing than FlyPapers; 20% smaller diameter threaded end on frontside bearing cup than FlyPapers, with finer pitch threads; top secret, super strong, military grade stainless steel alloy with better corrosion resistance than any other steel; and 87% stronger bearing shaft and pedal body than FlyPapers, making the HoneyBadgers absolutely the strongest pedals in the history of the World! (Over 64% stronger than the next nearest "spindley" pedal)...and...Due to the smaller diameter backside bearing and the smaller diameter of the threaded portion of the frontside bearing cup, there are MANY more cranks that will now work!
    If more people rode more bikes, more places, more often, the world would be a more better place!
  21. #1546
    Purveyor of Trail Tales!
    Aug 2005
    Quote Originally Posted by Bike Doc View Post
    I ride the Honey Badger Pedals because Honey Badger don't give a $hit where I ride or what I ride over or through!Click image for larger version.
ID:	928937Click image for larger version.
    Hey Dean,
    Congratulations on the new design and the fact it now fits a larger selection of cranks!
    Is it possible to retro-fit them to a pair of XT cranks or do you need to purchase a new crank set and pedals from you?
    Do you have pricing and availability worked out yet?
    Thanks, in advance, for the info!
    Take care,
    Michael
    If you can't keep the rubber side down......at least smile for the camera!
  22. #1547
    Aug 2013
    How do I become a tester?
  23. #1548
    Oct 2007
    So far, we have two testers; me, the designer; and Wil White who rode the Honey Badgers in the 2014 Red Bull Rampage. When you get your invite to compete in the Rampage, please let me know, and I will get you a set to test. Or, if you are racing competitively at the National Pro or World Cup level, or are starring in an extreme mountain bike video by a major production company, we may be able to work something out for you as well...
  24. #1549
    meow, meow.
    Sounds like early days. )
    26"
  25. #1550
    bike doc, thanks for posting about the honey badger pedals. 500g, not feeling it. Those showboating teeth do provide that shinburger appeal, gotta give you that. Good to see you back, too. I remember many years ago when your pedals were hinted on MTBR. How do your previous generation pedals and the current pedals compare to the Tioga ZEROaxle MT-ZERO (450g) which shared lukewarm reception. They were released at $150, then set for $99 retail, then dropped below $75.
