Results 1 to 6 of 6
Thread: Pedal bearings?
    Pedal bearings?
    Last season I purchased a set of Black Ops Torqlite pedals, seemed to work fine for trail use :
    Amazon.com: Black Ops Torqlite UL Pedals - 9/16", Black: Sports & Outdoors
    Last ride, during a slow climb, I noticed side to side movement from my left pedal. I put an allen wrench on the 4mm spindle hex bolt and found it was over a turn loose. After I snugged it down the pedal wouldn't spin @ all. I disassembled the pedal and found the worst bearing arrangement. Basically there is a 5mm bolt that serves as a bearing preloader & retainer. The bolt was covered in blue loctite. I checked the other side and a simple twist of the bolt and it backed right out. Anyways, I need to replace the bearings and don't know where to start as i can find no manufacture info.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    those pedals are a blatant copy of the twenty6 pedals. try contacting them and see what's up...
    Quote Originally Posted by .WestCoastHucker. View Post
    I looked @ the repair breakdown for the Twenty6 pedal and it uses a completely different spindle, bearing & retention system (legit).
    Pro Crastinator
    yeah, i thought the axles looked different in the pics. never seen either in person...
    Pro Crastinator
    http://www.jbimporters.com/web/check...t_number=19084
    they don't seem to have them in stock, but they have the part number and the maker of the bearing...
    Invoice Description PEDALS BK-OPS TORQLITE UL REP BEARING 6700VV INNER f/41687-91
    Brand Name: FORMULA
    Thanks I'll give them a call.
  1. When PD-M540 pedal bearings wear out, can you replace with XT or XTR parts? Better?
    By morkys in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2014, 08:20 AM
  2. Crank Bros. Pedal Bearings
    By pcxmbfj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-22-2013, 09:42 PM
  3. Cartridge Bearings versus Cup and Cone Bearings
    By caesar148 in forum Weight Weenies
    Last Post: 01-06-2013, 05:51 PM
  4. Time ATAC pedal rebuild (ceramic Bearings)
    By elpasotom in forum General Discussion
    Last Post: 05-30-2012, 07:58 PM
  5. Bontrager RE-1 Pedal Bearings? Any Pedal bearings?
    By davez26 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2011, 09:35 AM
