Results 1 to 5 of 5
    May 2013
    min/max stanchion setting
    newb here. i can't seem to find the answer that i am looking for google searching this. i picked up a 2007 Norco Atomik recently, previously set up by another rider with similar weight/height specs as me (great!)
    i am looking at the bike and the fork specifically. i see min/max lines located on the stanchions of the Marzocchi Super T forks.
    my question is... do these min/max lines adjust the travel of the fork? or is this just going to change the ride height of the front end? right now my bike is set up closer to the min line. would i see any benefit in running closer to the opposite end of the spectrum near the max setting?
    it appears it would just raise the front end travel by about an inch, which i could see being beneficial for steeper sections of the trail.
    Thanks for feedback/insight.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SkimSTi View Post
    Nothing to do with travel change.
    Everything to do with ride height and frame angles.
    mtbtires.com
    May 2013
    so was i correct to assume that more front end height (closer to the max line) would be more ideal for steeper terrain? or is this all personal preference.
    Personal preference. Higher front end means slacker head angle and higher bb.
    More slack is better for steeper runs. Less slack (shorter fork) is better for pedaling, and tight turns.
    The guy yo' momma "act" like she don't know!
  1. Replies: 8
    Last Post: 11-30-2013, 01:05 AM
  2. Stanchion lube?
    By reedfe in forum Shocks and Suspension
    Last Post: 08-28-2012, 03:45 AM
  3. Fox 40 Stanchion Tubes
    By mtbnozpikr in forum Downhill - Freeride
    Last Post: 09-19-2011, 09:50 AM
  4. Stanchion scratch fix?
    By slimat99 in forum All Mountain
    Last Post: 08-28-2011, 10:37 PM
  5. Scratch on Stanchion
    By Derekon in forum Shocks and Suspension
    Last Post: 07-25-2011, 10:56 AM
