min/max stanchion setting
Printable View
  • 06-30-2013
    SkimSTi
    newb here. i can't seem to find the answer that i am looking for google searching this. i picked up a 2007 Norco Atomik recently, previously set up by another rider with similar weight/height specs as me (great!)
    i am looking at the bike and the fork specifically. i see min/max lines located on the stanchions of the Marzocchi Super T forks.
    my question is... do these min/max lines adjust the travel of the fork? or is this just going to change the ride height of the front end? right now my bike is set up closer to the min line. would i see any benefit in running closer to the opposite end of the spectrum near the max setting?
    it appears it would just raise the front end travel by about an inch, which i could see being beneficial for steeper sections of the trail.
    Thanks for feedback/insight.
  • 06-30-2013
    shiggy
    Nothing to do with travel change.
    Everything to do with ride height and frame angles.
  • 06-30-2013
    SkimSTi
    so was i correct to assume that more front end height (closer to the max line) would be more ideal for steeper terrain? or is this all personal preference.
  • 06-30-2013
    bengxe
    Personal preference. Higher front end means slacker head angle and higher bb.
  • 07-03-2013
    Tim F.
    More slack is better for steeper runs. Less slack (shorter fork) is better for pedaling, and tight turns.
