Marzzochi Rocco WC leaking
Went for a ride today. At the end noticed oil trails out the compression adjuster, down the eye if the shock and down the down tube. I like the feel of the shock. This shock had a history of leaking oil. Had it pushed once and rebuilt by push once, both times oil started leaking shortly afterwards. Good thing I have another shock. I wonder if other people had problems with there roccos leaking.
Try sending it to avalanche
My Sponsor House
"I dont make memories, I make History."
CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
My pushed roco leaked out the rebound adjuster this season. Replaced some o-rings & seems to have fixed it.
Basically blew out all its oil in about 10 minutes of riding, thus ending my day. That's always a bummer when you've ponied up for a lift pass.
The o-ring of the compression assembly has failed.
I've got o-rings for the rebound needle if your Roco is leaking out the rebound adjuster. I had to buy a bunch of them. PM me and I'll send out 5 for a buck. Thanks.
Professional Troll
By Scarney19 in forum Shocks and Suspension
Last Post: 03-29-2010, 12:24 PM
By denjen in forum Transition Bikes
Last Post: 01-04-2010, 10:42 AM
By gvlasso in forum Shocks and Suspension
Last Post: 07-01-2008, 02:32 PM
Last Post: 05-30-2006, 11:36 AM
By tootsjofus in forum Shocks and Suspension
Last Post: 10-25-2005, 10:47 AM
- You may not post replies
- You may not edit your posts
Forum Rules
