Results 1 to 2 of 2
    REQUIRED FOR ADRENALINE!!
    Reputation: Gravity Assist's Avatar
    Manitou Swinger / Disco Volante Compatability
    Hey:
    Has anyone ever mounted a "Swinger 4 or 6 way" on a Karpiel Disco volante frame? Just checking to see if the linkage will clear and not smack the reservoir upon compression.
    Also, does anyone know what type of bearings this frame takes for the linkages?
    thanks again...
    I'm always right. I thought I wasn't once, but I was wrong.
    If you have the shock already mount it without the spring and check it. I ran a 5th element without it hitting and it had a pretty big resevoir. The bearings are standard 2rs ones that you can pick up at any bearing place. It should say on the side of them the size. I think they were 6 2rs.
