• 11-04-2012
    j.e.perry
    Leatt Neck Brace compatibility question
    Is the Leatt Neck Brace compatible with the following...:
    - fox rampage helmet
    Fox Rockstar Rampage Helmet - Fox Racing
    - fox titans sports jacket
    Fox Titan Sport Jacket - Fox Racing
  • 11-04-2012
    Rob-Bob
    The helmet should be fine but the armor does not look compatible. Most armor that is compatible will have a removable section at the top of the backplate and at the top of the chest plate. I know Troy lee and sixsixone both have models that work with neck braces.
  • 11-04-2012
    j.e.perry
  • 11-04-2012
    TheRage43
    The FOX suit it does not fit without custom modification. No idea about the helmet but most helmets work fine / well enough with the Leatt. Your best bet is to physically try the combo on and see if it fits.
    The Leatt Adventure suit fits very well with the brace. I picked up a very lightly used brace for cheap and got the suit on sale, had the small water pack already. I must say the combo fits together very very well. I haven't had the chance to actually ride with it yet but the try-on feel is better than the fox suit that I was riding previously. The only thing I noticed right away that I was prepared for is the lack of head movement, but the restricted movements are directions you shouldn't be moving anyways, so....
  • 11-05-2012
    j.e.perry
    can you give me a forsure recommendation on a helmet, because i have to order it online
  • 11-06-2012
    bs25
    I wear fox rampage helmet with my leatt brace and have had no problems.
  • 11-06-2012
    Rob-Bob
    bell drop..
  • 11-08-2012
    j.e.perry
    bs25 : what brace do you have?
    or are they all adjustable?
  • 11-26-2012
    j.e.perry
    Leatt DBX Comp
    I just received a DBX Comp and I have no idea which helmet will work for it. am going to order online; therefore I am unable to try on different helmets. Does anyone know which helmets for sure fit?
  • 11-26-2012
    IntenseMack10
    My TLD D3 works great. Before that I tried one of the newest Fox V3R carbons and it did not work at all. The outside shell of the helmet is HUGE, especially since its not a DOT helmet.
  • 11-27-2012
    j.e.perry
    does a giro remedy work?
  • 11-27-2012
    ron m.
    Practically all MTB full face helmets will work with the neck brace. I have used an Azonic Fury and now use a Giro Remedy. My buddies are using TLD and 661. The Fox Rampage might even give you a greater degree of movement (especially when you're looking up) since the chin line appears to be higher than other helmets I've used/tried.
    FWIW, I also use a Fox roost guard/chest protector that I modified (cut a section in the rear to accomodate for the spine bracket).
