Results 1 to 15 of 15
    The Lincoln Woods Crew
    Reputation: SOILWORK's Avatar
    Kink BMX headlock
    Just wanted to know if anyone has used one of these with good results. My LBS gave it to me at no charge. I am running a Cane Creek angle set and from what I read, you really have to tighten them down. This system looks solid. Thanks!
    "I push bike up and ride it down"
    Reputation: B-Mac's Avatar
    I have a similar gizmo on my DJ bike b/c the hardened steel steerer on my rigid DJ fork won't hold a star nut.
    They work fine. My only comment about the one you posted concerns the exposed threads and nut on the top cap. Seems like it would hurt worse and possibly cut you if you ever biffed into that. The one I use has a normal looking top cap. There's several available that don't have the sharp angular bits if you're concerned. If not, cool, disregard. I think that open part on the top is there for the purpose of running your front brake line through the steerer to allow bar spins, which are not possible on a dual crown DH bike obviously.
    Thanks! I am planning on running a second nut on top to to help in preventing it from loosening up and cover the exposed bolt.
    Glad to Be Alive
    Quote Originally Posted by SOILWORK View Post
    get a plastic cover or just shine that and get a headlock
    If you think you can
    Reputation: 62kona's Avatar
    I'm sure it works great but I wouldn't put it on my bike. I'd rather spend a little bit and get a headlock. That thing looks too out of place for my taste.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    that thing looks ridiculous. could it look any more ghetto?
    Quote Originally Posted by .WestCoastHucker. View Post
    I'm not concerned about it looking ghetto! I'm concerned about it working or not!! I have tried every other headlock system out there with the cane creek angle set and nothing has kept it tight! I have read plenty of post on this subject and most of the post seem to say that the problem is with the gimble and the bearings. After looking at it and and watching it loosen, I think the problem is the amount of surface area between the crown race and the gimble.
    EastBaySteez
    Reputation: Freerydejunky's Avatar
    Now sure how I feel about this...
    I run some ghetto ****, but this takes the cake.
    Gamut
    Team Evil
    Formerly: motormonkeyr6
    I use the Azonic Headlock with my angleset to keep her nice and tight.
    Reputation: bigb73's Avatar
    Oct 2007
    That headlock is about 15 yrs old. Came out in the mid 90's. It was made to keep your headset tight and if your fork ever snapped off, it would hold everything together a little better. I miss the old BMX days.
    what have you done to your headset that you need one of those? I have never had a problem with any threadless headset save kings coming lose. If you get everything aligned correctly, tighten to the proper torque, you're good to go. Sounds like either your shop or you fycked something up.
    Installed a Chris King Inset headset and Azonic headlock. She stays nice and tight now!
    can't fault you for running a headlock with a king headset, but you could have saved yourself time, money, and weight by switching to geico. And also running literally any other headset out there.
    Reputation: juanbeegas's Avatar
    Oct 2007
    Uh... Wasn't it meant to be run the other way round?
    Why did you ditch the angleset?
  1. Kink in my chain
    By Rearwheelslider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-23-2011, 01:32 AM
  2. Kink Liberty 09 *Or* Fit P1 05?
    By Gabriel47 in forum Urban/DJ/Park
    Last Post: 10-28-2008, 06:10 PM
  3. Kink Liberty OR Fit P1?
    By Gabriel47 in forum Beginner's Corner
    Last Post: 10-27-2008, 07:25 PM
  4. Definately a new kink.
    By Caffeine Powered in forum The ReCycle Bin
    Last Post: 11-24-2007, 08:58 PM
  5. Kink Kikapu or 575?
    By pogie in forum Bike and Frame discussion
    Last Post: 10-28-2004, 01:48 PM
