Kink BMX headlock
Printable View
  • 11-14-2011
    SOILWORK
    Kink BMX headlock
    Just wanted to know if anyone has used one of these with good results. My LBS gave it to me at no charge. I am running a Cane Creek angle set and from what I read, you really have to tighten them down. This system looks solid. Thanks!
  • 11-14-2011
    B-Mac
    I have a similar gizmo on my DJ bike b/c the hardened steel steerer on my rigid DJ fork won't hold a star nut.
    They work fine. My only comment about the one you posted concerns the exposed threads and nut on the top cap. Seems like it would hurt worse and possibly cut you if you ever biffed into that. The one I use has a normal looking top cap. There's several available that don't have the sharp angular bits if you're concerned. If not, cool, disregard. I think that open part on the top is there for the purpose of running your front brake line through the steerer to allow bar spins, which are not possible on a dual crown DH bike obviously.
  • 11-14-2011
    SOILWORK
    Thanks! I am planning on running a second nut on top to to help in preventing it from loosening up and cover the exposed bolt.
  • 11-14-2011
    SHIVER ME TIMBERS
    get a plastic cover or just shine that and get a headlock
  • 11-14-2011
    62kona
    I'm sure it works great but I wouldn't put it on my bike. I'd rather spend a little bit and get a headlock. That thing looks too out of place for my taste.
  • 11-14-2011
    .WestCoastHucker.
    that thing looks ridiculous. could it look any more ghetto?
  • 11-14-2011
    SOILWORK
    I'm not concerned about it looking ghetto! I'm concerned about it working or not!! I have tried every other headlock system out there with the cane creek angle set and nothing has kept it tight! I have read plenty of post on this subject and most of the post seem to say that the problem is with the gimble and the bearings. After looking at it and and watching it loosen, I think the problem is the amount of surface area between the crown race and the gimble.
  • 11-14-2011
    Freerydejunky
    Now sure how I feel about this...
    I run some ghetto ****, but this takes the cake.
  • 11-15-2011
    scottvt
    I use the Azonic Headlock with my angleset to keep her nice and tight.
  • 11-15-2011
    bigb73
    That headlock is about 15 yrs old. Came out in the mid 90's. It was made to keep your headset tight and if your fork ever snapped off, it would hold everything together a little better. I miss the old BMX days.
  • 11-15-2011
    William42
    what have you done to your headset that you need one of those? I have never had a problem with any threadless headset save kings coming lose. If you get everything aligned correctly, tighten to the proper torque, you're good to go. Sounds like either your shop or you fycked something up.
  • 11-15-2011
    SOILWORK
    Installed a Chris King Inset headset and Azonic headlock. She stays nice and tight now!
  • 11-15-2011
    William42
    can't fault you for running a headlock with a king headset, but you could have saved yourself time, money, and weight by switching to geico. And also running literally any other headset out there.
  • 11-15-2011
    juanbeegas
    Uh... Wasn't it meant to be run the other way round?
  • 11-16-2011
    scottvt
    Why did you ditch the angleset?
