Results 1 to 5 of 5
    Iron Horse Sunday Team or Scott Gambler DH 10
    Hi there!
    I´m looking to buy a used 2008 bike and it stands between a Iron Horse Sunday Team and a Scott Gambler DH 10. I´m kindly asking for opinions.
    CHEERS
    Spec!
    Name:Gambler DH 10 (08) US
    Built by:Scott
    Price:£3999.00
    Available Colours:Polished
    Frame & Fork:
    Frame Material:Alloy 7005
    Fork Brand:Fox
    Fork Model:40 RC2
    Rear Shock Brand:Fox
    Rear Shock ModelHX 5.0 with Coil Spring ProPedal and Boost Valve
    Brakes:
    Brakes Brand:Formula
    Transmission:
    Cranks Brand:TruVativ
    Bottom Bracket Brand:Truvativ
    Bottom Bracket Model:Howitzer
    Rear Derailleur Brand:SRAM
    Rear Derailleur Model:X.0 Short Cage
    Shifters Brand:SRAM
    Shifters Model:X.0 Trigger
    Chain Brand:SRAM
    Cassette:SRAM PG-970 12-26T DH Cassette
    Pedals Brand:Crank Brothers
    Wheels:
    Rims Brand:Mavic
    Rims Model:EX325
    Front Hub BrandT Swiss
    Rear Hub BrandT Swiss
    Rear Hub Model:FR440 for 12mm axle
    Tyres Brand:Maxxis
    Contact Points:
    Saddle Brand:Scott
    Seatpost Brand:Scott
    Stem Brand:Thomson
    Stem Model:Elite
    Handlebar Brand:Scott
    Handlebar Model:Pilot
    Scott Gambler DH 10
    Klicka på bilden för förstoring
    Årsmodell: 2008
    Märke: Scott
    Sizes
    Short
    Long
    Weight
    18.50 kg
    40.75 lbs
    Frame
    New Gambler Alloy 7005
    hydroformed tubing / carbon seatstays
    DH geometry / ISCG 05 tabs
    adj.headtube for 11/8 and 1.5""
    IDS interchangeable Dropout with
    12mm thru axle / 190-230mm travel
    IDS drop-out “Long Version” for 440mm chainstay length will be added in small parts box.
    Fork
    Fox 40 RC2 203mm travel
    titanium spring, preload adj. Reb/Comp High &
    low speed adj,
    20mm thru axle, alloy steerer"
    Shock (Rear)
    Fox DHX 5.0 coil, w/adj pro pedal
    Reb. Adj, Bottom out resistance adj, Boost
    valve, adj tuning range by air"
    Headset
    Syncros Hardcore AM 1 1/8""
    Derailleur (Rear)
    SRAM X0 9 Speed short cage
    Shifters
    SRAM X0
    Trigger Shifter
    Brake Levers
    Formula "the ONE" Disc
    Brakes
    Formula ""the ONE"" Disc / 2 piston
    203mm F + R rotor
    Crankset
    Truvative Holzfeller OCT 1.1
    36T alloy chainring
    BB-Set
    Truvative HowitzerTM 83mm shell
    Chainguide E.thirteen LG-1 ISCG05 Chainguide
    Handlebar
    Scott Pilot FR 1.5 Pro
    D.B, 38mm rise, 710mm
    H'stem
    Thomson Elite X4
    0° angle / length 50mm
    Pedals
    Crankbrothers Mallet M
    Clipless pedal
    Seatpost
    Scott RC 01-02 / 34.9mm
    5mm offset
    Seat
    Scott Gambler / 7mm CROMO rails
    soft Tail protection
    Hub (Front)
    DT Swiss FR 440 20mm axle
    Hub (Rear)
    DT Swiss FR 440 12mm thru axle /
    150mm wide
    Chain
    SRAM PC 991
    Cassette
    SRAM PG-970
    12-26 T DH cassette
    Spokes
    F: DT Swiss super comp black
    R: DT Swiss super comp black
    Rims
    Mavic EX 325
    Tires
    Maxxis Minion DHF
    front: 26 x2.5 3C 3ple compound
    rear: 26 x 2.35 supertacky
    Wire Bead, 2-ply DH casing,
    butyl insert, 60TPI
    _
    Reputation: slothoncanvas's Avatar
    Though the Sunday is(was) an amazing, amazing bike... I'd probably lean towards the Scott. Simply because at least with Scott you can call and talk to a person when something goes wrong with the bike. Iron Horse is completely gone.
    Reputation: Karve's Avatar
    Mar 2006
    Never ridden a Sunday but hear good things... of course the company is now a bit screwed so parts and warranty stuff might be an issue - best to check out the IH forum for the latest on that . I own a gambler.. see my write up here Scott Gambler - Initial Thoughts
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    gambler. the IH's have bushing issues and with IH going out of business it's going to be impossible to get them.
    HARDTAIL PRIDE- 09 Kona Five-0
    Quote Originally Posted by Djponee
    He should be fine, because the Sunday actually uses bearings - not bushings. And they just so happen to be easy to find for replacement when need be, in fact a full rebuild "set" can be pieced together from VXB.com (bearing's retailer) for under $20. All you need to do is pop out the old ones, look on the side sheilding for the bearing code (i.e. 6800-2RS) enter it in VXB's website and click purchase.
    Even though Ironhorse is temporarely adrift, they will be back. However the Sunday's awsomeness has never been adrift - it just is simply a perfect race bike.
