Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 69
  1. #26
    Quote Originally Posted by shwinn8 View Post
    .. No tv and no beer make Homer go something something....
    Yeah, that's it, thanks!
    '96 San Andreas
    '12 Santa Cruz Nickel LT
    '08 KTM 530
    '12 Toyota FJ TT
    '05 MiniCooper S
    '95 Honda HB Si
    '71 Dino 246 GT
  2. #27
    I used to bend seat rails a lot when I first started riding downhill since my legs were like noodles and I tend to sit a lot with my bum pounding on the seat as I go through rock gardens when I am tired.
    As i band-aid to my lack of skills/strength, I started using saddles with 8mm rails which are MUCH stronger and are MUCH MUCH more difficult to bend (don't think I have managed to bend one yet actually). Unfortunately, most 8mm DH saddles are heavy and uncomfortable until I started using the Tioga Spyder D saddle.
    The Spyder D was relatively cheap, strong, light and surprisingly comfortable for sitting and pedaling on flat ground but once on a DH track it would bump and bruise up my inner thighs badly if I am lazy and just sit through rough stuff. Because it really does punishes you HARD when you hit the saddle, it quickly trains you up to stop sitting or bumping into it while riding through the rough.
    Now my riding is much more fluid since I my ass is no longer glued to the saddle and the 8mm rails really does give the saddle strength and prevent it from bending. At 175g, it is also one of the lightest saddle within its price range (if you really do care about weight).
  3. #28
    Rep power- More than Hawg
    Reputation: Tone's's Avatar
    Id suggest buying DH saddles, they are made a lot tougher, im rocking a THE DH saddle, while its not to comfortable its a damn tough saddle.
    PARRAMATTA EELS R.L.C Life member- BLUE AND GOLD NEVER FOLDS..
    'Lifes not about winning or losing, lifes about choosing'
  4. #29
    GAME ON!
    ride with a post and no saddle and i bet you won't be landing improperly anymore.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
  5. #30
    Jun 2012
    Quote Originally Posted by saturnine View Post
    I second this.
  6. #31
    RideDirt
    Reputation: aedubber's Avatar
    Well unless thats his " thang "
    * 2013 Specialized Demo 8
    * My Youtube Channel AM/DH Videos
  7. #32
    Quote Originally Posted by zarr View Post
    Try the Syntace...You must be a very powerful rider to do these things.What bike/wheels do you use?
    I use regular wheels nothing super beefy. Stans Flow EX on an Mojo HD. DT Swiss EX5.1 on a Nomad. I9 Enduro build on a Nicolai AFR.
    Contrary to the impression I might have conveyed of how I ride, I'm a semi-smooth rider and my friends would probably say I'm not a hack rider. I've been biking for over 15 years so I've developed some skills at least.
    Remember, you are unique, just like everyone else.
  8. #33
    Maybe try out one of these seat posts?
    Seatposts
  9. #34
    FKA Malibu412
    Reputation: Glide the Clyde's Avatar
    It's your technique. It gets you to the bottom. Keep riding the same way and blowing up saddles.
    No matter how slow you go, you are still lapping everyone on the couch.
  10. #35
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    Quote Originally Posted by Aust95 View Post
    I hate to
    I hate to tell you this, but breaking lots of seats is basically the definition of a low skill/hack rider. You need to stop sitting down all the time and build up your leg/core/arm/everything strength.
    Santa Barbara
    My sick helmet cams
  11. #36
    Thank you.
    Attached Thumbnails Attached Thumbnails I am destroying too many saddles...need strong non-pig-like saddle suggestion-img00300-20121227-1133.jpg
  12. #37
    Reputation: shwinn8's Avatar
    Feb 2006
    sometimes you have to, you know, think out of the box and try something different. just remember, you made the post seeking a potential cause for multiple broken seats. you were probably looking for an answer that would result in product defect but the common feedback from many has been riding technique. change can take time, just takes practice...
    '00 Homegrown
    '01 Straight8
    MTBR's Fantasy Nascar League: http://forums.mtbr.com/10060117-post1190.html
  13. #38
    Professional Troll
    Apr 2005
    I like this guy.
    Also, I think I've literally never heard of someone breaking multiple seats. And I've rarely seen anyone break a single seat.
    Santa Barbara
    My sick helmet cams
  14. #39
    Reputation: shiggy's Avatar
    Dec 1998
    If you are breaking things that others do not, the issue is you, not the thing that is breaking. You either adjust your technique, or keep replacing broken parts.
    mtbtires.com
  15. #40
    Feb 2006
    lower the post so all you can read is " THOM" or '' THO ''
    '00 Homegrown
    '01 Straight8
  16. #41
    There is a slight possibility that there is something wrong with the post. Try a different one and see what happens.
    '96 San Andreas
    '08 KTM 530
    '12 Toyota FJ TT
    '05 MiniCooper S
    '95 Honda HB Si
    '71 Dino 246 GT
  17. #42
    Probably riding sitting on the seat while going over obstacles.
    Are you getting of your seat when you are going over the obstacles or doing jumps? If not than that is whats causing them to break. Start riding on your pedals while going over stuff and you will solve your problem.
  18. #43
    DenverDH'er
    Reputation: rep_1969's Avatar
    I've bent few rails in my days of DH. When I get really tired on a run, I'll sit down and pedal on the "flat" parts of a trail. This will in time bend the rails because when you're going that fast, even a smooth stretch of trail will put considerable strain on the rails when seated. Now if you're doing this on drops, that's just odd. You shouldn't be contacting your seat on jumps and drops.
  19. #44
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    I broke a saddle once....pelvis too.
    NOAH SEARS
    MRP
    WHITE BROTHERS
    TECH QUESTIONS HERE: INFO@MRPBIKE.COM
  20. #45
    IF your bike is a mojo then you should buy a dropped post you will be able to drop it when you need
  21. #46
    Gotta be user error or you are somehow installing them incorrectly. Never in my 10+ years have i broken a seat. Even crashing and sending my bike flying down the hill, never has one broken. Was previously on I-beam wtb, and now regular rails with a wtb devo
  22. #47
    Oct 2010
    i like the lounge. Its BEASTLY
    Azonic Lounge Seat Saddle Reviews
  23. #48
    Dec 2009
    Land on your ass??
    You're gonna slip a disc or give yourself ED
  24. #49
    The Sette Strike DH saddle lasted me a long time. I went from it to a Chromag Lynx & the Sette has larger diameter rails than the Chromag plus the Sette is cheap. I think it's called the Strike.. I bought it after destroying a saddle when the bike flipped into a tree.
  25. #50
    GAME ON!
    Quote Originally Posted by Mountain Cycle Shawn View Post
    nothing wrong with the post. it's a thomson.
    RIP Adam Yauch
Hot Deals
Contests
Latest Mountain Bike Articles
