How to approach a jump
Hey guys, I was wondering what is the best position to put my body in when approaching a steep jump. Whenever I hit a steep jump I don't feel loose and I do not get that much air. I have no probs on any other type of jump just the really steep ones get me. Any advice?
Just take off the silver part you'll still have the pretty anodized partion, and you'll ride much faster. As fast as a 29er!
I'm no expert but ill give you my experiences on jumping.
When I started mtb I used to just go over all jumps with no preparation. Basically I used to stiffen up nervously and hit the jump and basically pray I would somehow land ok. Obviously not good.
After I learned to bunny hop i used to try do that on jumps. Pull up on the bars and then kind of lift the back a bit on the lip. This worked better than praying but still wasn't great. Sometimes the back would buck or I would lift the handlebars too hard. So in air balance really wasn't great and I had no idea which wheel was going to land first.
Finally the best method I learned was to stay really loose, crouched, with chest forward. When you enter the ramp you then push the bike down and forward into the face of the ramp. This compresses the bike and when it gets to the lip it should want to pop now. At this point you can relax and straighten out a bit for a small lift or stand tall and really unload your weight from both the pedals and handlebars to really pop off the lip.
Again I'm no expert but one thing that frustrated me about mtb was that no one could clearly explain anything to me. Lots of people would say I sucked at something but then be unable to explain what I can do better to fix it. Watch me would be the answer but watching someone else is not easy when they can't explain what they doing because they just do it subconsciously.
Yeah. Thanks man. Good tip. Ill remember that. I can hit the not so steep ones and get good air and preload good but the steeps get to me haha. But I think what you said will help alot
I think that it would be very difficult to top jasonjm's response. Confidence is obviously key but not enough can be said about staying loose. I do not consider myself an expert either and am more into the downhill and technical terrain than the FR but as with anything else it will take a lot of practice until you feel comfortable yourself.
2012 Intense M9
2012 Pivot Mach 5.7 Carbon
2008 Look 595
2007 Custom Litespeed Sewanee
its hard because the jumps that are either have long ramps or are not steep you actually are in theory almost "riding off".
the suspension gets time to fully decompress by itself or doesn't compress at all, so you can just relax and ride off like its part of the trail.
__________________________________________________ _______________
now compare this to a very short take off ramp, or a very steep lip, or even a not so steep ramp, but one that you hit coming in hot. When you hit these the bike suddenly has a huge change in direction. Full suspension bikes especially are going to fight you here, because they are DESIGNED to soak up the hit.
so what happens if you do nothing?
A) the fork compresses as you go up the short ramp, or the steep lip.
B) this throws your weight off, most likely forward on the bike, at the very least bracing hard on the handlebars
C) now the rear doesn't have a lot of weight on it, so the the shock doesnt compress nearly as much as the fork did, and the bike now tries to "buck" on the jump because the rear wheel has a much easier / less weighted time riding up the face of the ramp.
so at this point you are either going over the bars, or you are going to be all screwed up in the air fighting a bike that has just randomly kicked you into the air depending on how fast you came in, how much rebound your shocks have and how steep the lip was.
Again I am no expert but having watching tons of riders at 120fps to 240fps and doing a lot of these jumps in the last year, the only way to do these kinds of jumps is to take the control of the bike back from the jump and into your hands.
and the only way to do this especially on a full suspension bike is to load the bike down and pretty much 45 degrees into the face of the ramp.
its not a massive aggressive move though its subtle and well timed, and relaxed.
when you do it right you can just feel that the bike and your body WANTS to leave the ramp, and that's when you can stand aggressively and just pop for air.
if the bike doesnt feel like it wants to jump because your didnt load it, if you stand aggressively for big air you are just going to literally go flying off the bike (I did that plenty).
A very good indication that you are not pre-loading well is when you jump often a foot comes off the pedal or you feel like your feet want to come off the pedals.
Hope I am helping, again I am no expert, but I am a very good at observation (IMO).
OMG... you nailed my last dead-sailor experience to a T. Good explanation, Jason.
BTW, I haven't really done it yet but I watched a couple of other guys hit the same lip I dead-sailored on, and in their case, they had seem to be up on the bars during take off (which makes sense, since the center of the bike on a lippy take-off moves your body way forward). At the apex of the flight arc, they seem to push the bike down and point it towards the tranny.
I haven't balled up to that jump since so I don't know if "pulling the bar" at take-off would work.
When you have a good lip, you press off of it just like a bunny hop. Front tire, then rear tire, you just have to do it off the face of the jump so it feels weird. You end up leaning back a bit to do it. You have to ride the ramp up then push off.
no it doesn't if you concentrate on pulling up on the bar you will screw up. Once you are balanced in the air pushing down on the bars to land is actually easy.
you have to start by pushing down into the ramp
that's what makes this whole thing so counter-intuitive - its like going left to go right.
if you push down into the ramp, when you get to the lip the bike will be pushing up into you when you get to the lip. This is the point that you can start pulling up on the handlebars and pedals, because the bike is moving up into you. even then you don't really pull up, you more stand and extend
if you just try pulling up you will get into trouble, trust me. I spent 100s of jumps just pulling up and couldn't understand what was randomly going wrong.
take a look at this guy, he definitely knows what he is doing (no way to doubt he is an expert).
go to 1 minute 18
you can CLEARLY see him loading into the jump - which really is not a very big jump either.
Mountain Bike - Jumping Downhill - YouTube
"Bar humping" actually helps out to correct or level the flight path of your bike. It looks fugly but, it will help you loosen up or get you on the receiver in a jump you are not used to.
Great! Thanks for these tips, and advices. Now just need go practice over and over.
Thanks for the help guys. Only problem is I have to wait for winter to be over before I can ride
The jumping tips are very descriptive... Thank you Jasonjm
F*ck Cancer
Eat your veggies
go to 1 minute 18
hah!
and if you go to 1 minute 38 you can clearly see someone do two sucky attempts, no loading whatsoever, almost over the bars on the bad landing into gap.
gotta say, i have done a lot of sports, including some pretty difficult ones (like hangliding), and mountain biking has by far the least and the worst instruction out of any sport I have ever done, by a mile.
probably one of the best videos on the internet, you can compare greg minaar doing it right to average joe screwing it up (and that was definitely me when I started jumping, I could have been the star of 1 minute 38).
go to 1 minute 18
Whoa, Minnaar on a Honda...classic video!
to all who are still confused about what is going on in that video I posted, watch carefully at 1 minute 18
its EXACTLY like I said
look at his fork
he compresses it almost fully before he is even starting up the ramp, its fully compressed the split second he is heading up the bottom of the ramp
why does he do this?
because now the only thing the bike can do is decompress, so instead of his fork and shock fighting him on the jump they are going to help him now, buy boosting him off the lip (in this case he also stands tall to get even more air).
you can clearly see the first thing he does is get low and compress into the ramp
he does NOT pull up on the bars first
the steeper the ramp or lip, the more aggressively forward you need to be. Again its counter intuitive, you would think be back on a steep ramp? no, you gotta be more forward.
In my mind when I hit the jump I think chin above stem. definitely in the air you should be thinking chin above the stem. in reality you are probably never really quite that far forward on the bike, but it helps thinking like that.
the only thing that matters is that you go full speed and close your eyes.
Watch Girl Flies Into Lake Off Bike Jump Video | Break.com
here is full speed, not sure if her eyes were closed
but she definitely gets style points
Like a boss!
F*ck Cancer
Eat your veggies
it's all about pumping the transition. the steeper the lip the harder you should be pumping. what clicked for me was being able to start generating speed on a pump track just from pumping. Jumping is the exact same feeling as pumping but with some hang time in the middle. the other thing that helped me was to stay loose, keep most of my body weight on the pedals, and pump aggressively, really push that bike down into the ground.
 Originally Posted by aedubber
Lots of practice
Wurd. Muscle memory.
yeah of course a lot of practice
but as in any sport, if you practice the wrong technique, all you are doing is reinforcing how to do it wrong
then if you ever get to the point where you try learn the right way it may be extra difficult because now you have tons of experience doing it the wrong way.
better to start practicing the right way from the start even if its harder initially.
Subscribed as im learning! One of my issues is landing as well! I tend to get all squirly! Probably stiffing up too much bracing for the landing!?
It would be great posting videos, makes it easier for us to debate on the issue at hand.
- You may not post replies
- You may not edit your posts
Forum Rules
