Results 1 to 8 of 8
Thread: Helmet Vote
    Jun 2013
    Helmet Vote
    POC Cortex Flow vs. One Industries Gamma
    One Gamma manufacturer description:
    • Dual density EPS liner inserts
    • Large intake and exhaust vents and fully channeled liner
    • Snap in comfort liner and cheek pads
    • Moisture wicking Nylex comfort liner
    • Enlarged eye port
    • Unique 2-position visor adjustment.
    • Pre-preg, reinforced fiberglass
    • Superior impact protection with progressive energy absorbing inserts
    • Increased cooling from flow-through ventilation
    • Easily cleaned
    • Plush comfort with moisture management liner
    • Large peripheral visibility. Great goggle fitment
    • ECE/DOT 1325g
    POC Cortex Flow manufacturer description:
    • A generously ventilated full face helmet with an outer shell made of fiber glass. The fiber glass shell is slightly heavier than carbon fiber but on the other hand, it is more durable. The liner is made of multi-impact EPP, which means that the helmet withstands numerous crashes without having to be replaced, s would any other EPS helmet. The open vents allow more air to flow through the helmet, increasing the user comfort. So, for all those fearless riders out there eating dirt, this should be their choice. Sizes: S/M, M/L & L/XL.
    • 1000g
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    whichever one fits better, duh...
    Jun 2013
    Both fit great
    Pro Crastinator
    i'd be more inclined to go with the One Industries Gamma then. it seems like a much better helmet...
    Jun 2013
    Yeah but there's also the weight factor. The cortex weighs 350g less
    Jun 2013
    The gamma feels more plush and solid but its also a lil bulky, has a larger profile, and weighs 1350g
    The cortex is lighter at 1000g and lower profile..
    Pro Crastinator
    in the end, it's your brain that you are trying to protect. to me, my brain is worth a lot more than 350 extra grams...
    Perpetual Hack
    Reputation: mykel's Avatar
    Big difference is in the type of foam used.
    Gama is EPS foam - basically one good hit and replace. EPS tends to crack, and deform permanently.
    C-Flow is EPP foram - multi-hit capable. EPP tends to bounce back and is capable of absorbing multiple impacts.
    michael
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
  1. Vote for favorite Bell Helmet project
    By DennisF in forum North & South Carolina
    Last Post: 03-24-2013, 05:54 PM
  2. Artscyclery.com Cannondale Teramo helmet (yep, a great helmet)
    By westin in forum Where are the Best Deals?
    Last Post: 10-30-2012, 09:34 PM
  3. Replies: 9
    Last Post: 11-08-2011, 09:42 AM
  4. Replies: 36
    Last Post: 07-08-2011, 09:45 AM
  5. GoPro helmet placement/mounting tips? (on FF helmet)
    By kdiff in forum Downhill - Freeride
    Last Post: 01-11-2011, 09:53 AM
