• 01-28-2013
    mudtoy1986
    headset removal in 04 stinky
    hey guys i have an 04 kona stinky with a chris king steel H/S and i cant get it to move so i can send it in for servicing has anyone had this issue before i need help
    ive used the proper tool and ive also used a flad head screw driver
    any advise would be great
  • 01-28-2013
    DYI01
    I've found that as a last resort use a 3/8" or 1/2" drive, long socket extension and a BFH do the trick.
  • 01-28-2013
    mudtoy1986
    ok thanks for the reply
    what about heating the head tube and PB blaster?
  • 01-28-2013
    VTSession
    Spray the PB blaster and let it soak in for 24 hours. Used to do that back in my bike shop days, usually works.
  • 01-28-2013
    .WestCoastHucker.
    just hit that sucker harder. don't be scared, you aren't gonna break anything....
  • 01-28-2013
    mudtoy1986
    thanks for the replies guys
    i have been hitting it it seems that the headtube is recessed so i only have about 1/2 the lip to bite on with the tool
  • 01-28-2013
    -Todd-
    Ice the cups and heat the headtube.... Loctite makes a penetrating oil, Freeze and Release that shock freezes seized parts, might be handy for this kind of problem.
  • 01-29-2013
    mudtoy1986
    thanks for all the help guys ill check into the freeze and release
  • 01-29-2013
    .WestCoastHucker.
    you don't need heat/ice gimmicks, you need to whack the headset harder. stop acting like a girl and smack the F out of it and it will come out...
  • 01-29-2013
    _rich_
    I know exactly what you are talking about..
    I remember having the same trouble..The tubing in the headtube on the Stinky is very thick.It's then machined down to the size of your headset..
    This leaves a lip thats totally in your way from the inside when you are trying to remove the headset..
    I remember making a special tool out of a elcheapo 3/8th socket extension..
    Grind part of the side off so it sticks into the small area you do have to work with?
    oh, and it being a steel headset probably makes it worse..if i remember correctly they go in deeper?plus steel and aluminum have a habit of seizing up when they are use together :(
    goodluck...
  • 01-30-2013
    mudtoy1986
    i just ordered a new H/S removal tool in hopes that a fresh edge on the tool will bite the H/S better
    ive tried hitting the H/S harder all the tool did was slip past
    thanks for all the replies guys
