Results 1 to 7 of 7
    Reputation: Calidownhiller's Avatar
    Headset for my new glory and chain guide Question
    Hey,
    I just bought a glory frame used, and it didnt come with the headset bearings or anything, just the cups. Is there a single headset that I can buy for the glory, or do I have to mix and match two different ones to make it work?
    Also is the Chain guide ISCG or ISCG 05?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Gravity makes a tapered and a tapered reducer headset. You can order Cane Creek top and bottom cups individually.
    Former Ninja
    I'll save you 5 minutes with the ruler and tell you that Giant uses ISCG-OLD on all their bikes.
    I'd personally do somthing like the SRS+ for that bike. Set and forget.
    thanks, i'll look into that.
    Funny I just did the same thing. I ordered a set of e.13 reducer cups, will be popping out the lower cup and throwing one of those in. Then all you need for a headset is an integrated headset, just bearings basically. like an IS-8. the upper cup you would just reuse and then drop in the upper bearing from the IS-8.
    Like Phil said, ISCG old.
    Quote Originally Posted by dagmz6s
    Damn, thats a good idea, I wish you could have given me that idea about 5 hours ago before I had ordered a Gravity sxe mixed tapered and integrated.
    Glad to Be Alive
    thank me later and get an FSA orbitz
