Results 1 to 7 of 7
    Headset & Bottom Bracket Grease???
    I was told by a bike tech that the shop just uses Mobil 1 Synthetic Grease (auto grease) for Bearings on the Headset, Bottom bracket, suspension. He said all the bike greases are cheap auto grease and don't last as long as Mobil One.
    Does anyone else use auto grease for bike bearings? It sure is cheaper than bike grease.
    Glad to Be Alive
    I have used it in the past with no problems....You can even use strait vasoline
    but I like the clear White lightnening greese now days
    Reputation: oopsthathurt's Avatar
    Aug 2013
    Being South Florida and all, I just drip sweat all over the bike and it stays lubed.
    2014 NS Bikes Clash 1 - all original
    2014 Trek Fuel EX 7 29er - modified
    2013 Trek Mamba 29er - modified
    Jan 2011
    Reputation: MotoDane250's Avatar
    I been using it for the last few years and have never had any issues with it. Just built up my gf's new bike with it last night.
    Reputation: charging_rhinos's Avatar
    yep, auto grease for me too. Many bike companies just buy and rebrand auto grease anyway. I don't see Park Tool having on-site chemistry labs. There are different types of grease though, so just pay attention to what you get as it will make a difference. Greases are usually rated as NLGI#0, #1, #2, or #3. The higher the number, the thicker and stickier the grease. NLGI 0 is extremely watery and I'd not recommend it for anything on your bike. For a BB, linkage pivot, or headset, I'd suggest NLGI#2 in either synthetic or normal. NLGI#3 is just too thick in my opinion, and you might get some churning/aeration if you pack a lot of it into the bearing. Additives in the grease like Lithium (often denoted along with an 'EP' in the name) are nice for high-pressure situations, but are not really necessary for the loads you'd see on a pair of cranks.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Reputation: watts888's Avatar
    Oct 2012
    I use marine hub grease (boat trailer axle grease) because it's a bit more water resistant. I get it from harbor freight in the smaller grease gun tubes because I don't go through so much that I want to bust out a huge tube, I can cut the tube length down pretty easy as I use it, and it's a bright blue so I know what I've lubed & cleaned and what the LBS/OEM lubed.
  1. Do you grease your headset cups???
    By CragRat in forum Turner
    Last Post: 12-11-2013, 05:17 PM
  2. Angleset Headset and Bottom Bracket height
    By Ottoreni in forum Frame Building
    Last Post: 11-26-2013, 05:16 AM
  3. Press fit headset and Bottom Bracket
    By dstepper in forum Turner
    Last Post: 09-28-2013, 03:39 PM
  4. Bottom bracket threads - grease or anti-seize?
    By peternguyen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-25-2013, 11:43 AM
  5. Grease on top of Chris King headset cartridge bearing?
    By Krause in forum General Discussion
    Last Post: 09-08-2012, 10:58 AM
