Results 1 to 27 of 27
    Hardrock Pro Disc or Voltage YZ 0
    Hey guys, i'm needing some advices about those bikes...
    What do you think that it's the best buy?
    Specialized Hardrock Pro Disc
    Scott Voltage YZ 0
    Thanks...
    notabouttoseeyourlight
    Reputation: coma13's Avatar
    For what kind of riding?
    Your username isn't in reference to the band Tragedy is it?
    cycle tracks will abound in utopia.
    Reputation: lebikerboy's Avatar
    Jan 2005
    The Hardrock Pro is a good bike except for the Made in Taiwan Marzocchi. Don't know anything about your other choice.
    Quote Originally Posted by coma13
    It's for some kind of light-freeride
    And no, the nick isn't in reference to the band Tragedy, but to Tragedy Khadafi.
    Reputation: mountainbiker9109's Avatar
    The Hardrock Pro disk is better. I have one and I love it. Its components are a lot better than that on the Scott Voltage YZ 0.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Actually the Scott is a lot better.
    Scotts components are a lot worse. Hardrock has Deore and scott has alivio shifters. Think again.
    Florida Rider
    Reputation: atomrcrkhsbiker's Avatar
    I vote for the scott...
    Didn't Timo Pritzel used to ride one...
    Reputation: standard235's Avatar
    Go for the Scott. That Dirtjam pwns the MZ Comp. I'd live with Alivio components... just go to parktool.com and learn to tune your own stuff. It used to seem really hard but I can do it so easy now, it's no way worth the labor cost for having a deraileur tuneup...
    Now having a wheel laced... yeah.
    Meh.
    Quote Originally Posted by mountainbiker9109
    Frame construction and fork is MUCH better. Alivio or Deore shifters, big deal, they're both low end. And all Shimano shifters/derailleurs use the same mechanisms, just different materials. Bars, stem, cranks, wheels are also better. Pro disc has slightly nicer brakes.
    Hardrock is an entry-level recreational bike. The Voltage was designed with some sort of abuse in mind.
    So why don't you think again?
    As of now, I'm still working at a Specialized dealer too.
    If it's actuaaly the Pro Disc that you're looking at, then the specs are way better. I currently have a Pro disc. It has SRAM X-7 shifters/deraileurs and Avid mechanical disc brakes. I love mine, it can do anything i want. Only bad part is the fork, as stated above.
    Quote Originally Posted by standard235
    hahahah i can do that, you little pussv.. jk its hard as hell but i can do it..
    also i say get the scott
    I went to the doctor and told him "hey doc, it hurts when I go like this" and the doc said "Does the rear feel too soft?"
    Yeah the X.7 IS nice. You could buy the Pro Disc and do a tradeup with Marzocchi for $100 for a DJ3. Tis what I did.
    Just don't do hops on the back wheel with the rear brake. I snapped the frame that way.
    Meh.
    It's an entry level recreational bike. Enough said.
    Lacing wheels is all about patience, and even spoke tension. Get a tensiometer.
    And spoke prep. Can't forget that.
    Go for the Scott though.
    But my Hardrock survived a ton of 5ft to flat concrete so who knows.
    Meh.
    Spoke prep isn't that important. High quality nipples are a must so they don't crack or freeze. Spoke prep can help keep them from seizing.
    Tension is everything.
    Get the Scott. Slowly take over Timo's life.
    Lol cool discussion...Well i think that i'm gonna buy Voltage YZ0, besides she's definitely more pretty
    Thanks for the info mates.
    crumb
    Reputation: saviorself's Avatar
    Dec 2004
    Yeah get the Voltage, easy choice
    e.f.f.e.c.t smoothoperatr
    Reputation: themarsvolta55's Avatar
    Dec 2004
    the scott is hot and nice and good and better looking
    rockin the mid-west
    Reputation: madtownfreerider's Avatar
    go with the Scott
    PUNK FOR LIFE
    freeride & Down hill for life
    Companies I support
    E-13
    Shimano
    Maxxis
    EBC
    Marzocchi
    SIXSIXONE
    Specialized
    Arrow Racing
    Truvativ
    W.O.R.B.A. supporter
    I.M.B.A. supporter
    Hey, is Kona Shred a good option too?
    Meh.
    Yes, the Konas are very solid frames. The drivetrain on the Kona isn't as good as the Scott. But you get some better parts too. It's a great platform to upgrade. Ride both the Scott and the Kona, see which you like better.
    I'll.
    Much appreciated for the info mate, thanks.
    I CAN ALWAYS GO BIGGER
    Reputation: RYAN E's Avatar
    the pic of the HR is a pic of the 05', the 06' comes with single tracks, avid bb5's,and a x-7 rear derailler.you can buy an new 05' p.2 for a $100 cheaper than the pro disc
    the Scott hands down, in my opinion every good bike should start with the best frame possible, and that'd be the Scott, very well built, burly and 4.1 pounds if not mistaken even if it did have *slightly* worse build, the frame is the key component to every bike and will be the main deciding factor in how your bike will ride / survive.
    Meh.
    Specialized doesn't have any o5 p.bikes left in their warehouses, so unless your LBS has leftover inventory that they're clearing out... that deal doesn't apply.
    your right the factory does not have any more but the shop I work at has about 5 left
