Results 1 to 15 of 15
Thread: Gator brake
    Reputation: A.P.B's Avatar
    Gator brake
    Does any one know anthing bought these brakes.
    I am looking at the six piston designe but cant find any info on them on the web . Their home page does not offer much.
    http://www.gatorbrake.com/
    I was going to post the same. Supposed to be good, as per a thread in the archives here. The only issue I see if they are really the real deal is getting replacement pads and parts. If you buy one, get the replacement pads now because PP is the ONLY place to get them, it seems.
    I couldnt find any reveiws on mtbr at all do you have that link?
    PULL
    Reputation: NoManerz's Avatar
    Feb 2006
    I thought I read that they were horrible in an old thread. Do a search.
    Useful
    Quite useful info their. Thanks Already did a search!
    PULL
    Feb 2006
    want me to spoon feed you?
    Gatorbrake 8 piston DH brake....wowzerz...
    Please do Like to have people like you do my work!!!
    Reputation: rmbnick's Avatar
    for what reason do u need 8 pistons unless you weigh like 500 pounds
    GETOFFTHEBRAKESYAFAIRY
    Flying Goat
    Reputation: mrpercussive's Avatar
    actually... the more pistons the less power i think cause you're applying the same amount of force to more pistons. Better modulation though. 8 pistons is definitely overkill...
    Quote Originally Posted by mrpercussive
    No, not necessarily. Multiple pistons can also help push a longer pad out more evenly. This longer pad would produce friction due to more surface area. In this manner, a staggered size, multiple piston layout would produce more power, as well as helping modulation.
    problem with all those pistons is
    your master cylinder is going to have to MOVE a lot of VOLUME of FLUID to make it work well.
    If you remember correctly some of the first designs for disc brakes used VERY LARGE master cylinders, almost like some motorcycle parts, worked OK, but very heavy.
    Andy, invest in some SAINT or CODE brakes and you will never look back.
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    Road/XC/Freeride
    Reputation: Ace1's Avatar
    I'd be willing to test some if Alligator would oblige but it does seem like overkill for overkill's sake.
    I think most people would agree that the Hope M6 Ti is too much for the majority of people/bikes (though I would recommend them as the finishing touch to you ultimate DH sled).
    With a pad that long it's bound to be easy to lock-up (assuming even pressure from all pistons) unless you're one hell of a big boy (or girl).
    I'm on the Twitter.
    Glad to Be Alive
    Quote Originally Posted by General Havoc
    true dat...and parts are easily available
    General Rabble-Rouser
    Reputation: Karupshun's Avatar
    I've read the gatorbrakes are utterly terrible for modulation, and overall they don't preform much better than Juicies
    stick with what works
