    hands up who wants to die
    Reputation: rpet's Avatar
    FSA euro BBs: Euro Pro vs. X Drive
    OK - what's the difference between these two 19mm BBs that FSA makes?
    thanks
    -rob in NYC
    Former Noob Herder
    Reputation: zedro's Avatar
    you know i was wondering about this the other day since i need to replace the bearings on my x-drive BB. I'm not sure if this is a misrepresentation, but the website says the Euro-Pro has "2x double-row deep-groove full-complement sealed cartridge bearing". If in fact they use true double row bearings (ie. two bearing circuits share the same races), then the Euro is superior to the X-Drives 4x single row bearings.
    I'm having tensioning problems with the x4 setup; has to do with how the cranks push on the races and spacers yadda-yadda...anyways, i might call FSA so see if they have double row and if i can get replacements.
    Also the Euro-pro has a lighter hollow axle, and looks cooler.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Cool - thanks for the info! I'll go with the Euro Pro then...
    Anyone know how the Euro Pro axle compares in weight to other 19mm spindles?
    thx
    -r
    Former Noob Herder
    FSAs kinda notorious for spotty info, but the x-drive BB assembly is listed at 487g and the Euro at 384g, and running some quick numbers i cant see the axle itself being any lighter than 50g's really.
    If you really want to trim some weight, there is a Ti axle (might wanna call FSA on that one too), and Profile also makes a Ti axle, but the Ti wont be as strong as the steel alloy one.
  1. paging all FSA carbon pro crankset users.....
    By marco in forum Weight Weenies
    Last Post: 06-24-2004, 07:09 AM
  2. Replies: 0
    Last Post: 04-08-2004, 08:40 AM
  3. Replies: 24
    Last Post: 04-06-2004, 08:58 AM
  4. Loose FSA Carbon pro crank arm
    By Trevor! in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2004, 08:21 AM
  5. FSA Team Issue Carbon Pro Porn...
    By DIRT BOY in forum Weight Weenies
    Last Post: 03-04-2004, 08:31 PM
